Prove: f(x) = e^{cx} for some constant c
  • Thread starter Thread starter ehrenfest
    Constant
The problem involves proving that a function \( f(x) \) satisfying the functional equation \( f(x)f(y)=f(x+y) \) for all real \( x \) and \( y \) can be expressed in the form \( f(x) = e^{cx} \) for some constant \( c \). The discussion includes two parts: one assuming \( f \) is differentiable and the other assuming only continuity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss differentiability and its implications for analyticity, with some questioning whether \( f \) can be shown to be analytic. Others suggest using power series comparisons to explore the relationship between \( f(x) \) and \( e^{cx} \). There are also attempts to establish limits and their significance in proving the functional equation.
The discussion is active, with various approaches being explored. Some participants have offered insights into the implications of differentiability and continuity, while others are questioning the assumptions and definitions involved. There is no explicit consensus, but several productive lines of reasoning are being pursued.
Participants note that the problem may involve constraints related to the definitions of differentiability and continuity, and there is mention of specific examples from literature that challenge common assumptions about these concepts.
ehrenfest
Suppose f(x)f(y)=f(x+y) for all real x and y,
(a) Assuming that f is differentiable and not zero, prove that
[tex]f(x) = e^{cx}[/tex]
where c is a constant.
(b) Prove the same thing, assuming only that f is continuous.
(a) The given information implies that f(x)^2 = f(2 x) and furthermore that f(x)^n = f(n x) for any natural number n. We can differentiate that to obtain f(x)^(n-1) f'(x) = f'(n x) for any natural number n.
It is also not hard to show that f'(x) f(y) = f'(y) f(x) for all real x and y.
We can take y = 0 to find that f(0) = 1 (I have used the fact that f is nonzero here).
For (a), would it not be easier to compare the power series of f(x) and ecx.
Perhaps, but I don't know how to prove that f is analytic.
You're told f is differentiable which is just another way of saying that it's analytic.
differentiability implies analyticity only in complex analysis. Rudin even gives an example of a function that is real-differentiable but not analytic in Exercise 8.1
show that a and b each imply
lim_{h->0}[f(h)-1]/h=c
and then
with
imply
f(x)=exp(cx)
and then
with
imply
f(x)=exp(cx)
I can prove part a). I can see how it would be enough to show that continuity implies lim_{h->0}[f(h)-f(0)]/h exists but I don't know how to do that.
You are given that f is differentiable.
f(x+h)- f(x)= f(x)f(h)- f(x)= f(x)[f(h)- 1].
[tex]f'(x)= \lim_{\stack{h\rightarrow 0}}\frac{f(x+h)- f(x)}{h}= f(x) \lim_{\stack{h\rightarrow 0}}\frac{f(h)- 1}{h}[/itex]<br /> and <b>because</b> f is differentiable, that limit exists.[/tex]
[tex] <br /> I said I could do part a).<br /> <br /> But lurflurf said that (b) also implied that the limit exists.[/tex]
  • · Replies 21 ·
