Questions regarding DC circuits
  • Context: Engineering
  • Thread starter Thread starter R A V E N
    Circuits Dc
The discussion centers around the resistance between two points, A and B, in a simple DC circuit. Participants explore the implications of ideal conditions versus real-world scenarios in circuit analysis.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions the resistance between points A and B, suggesting it should be zero since current flows through the path of least resistance.
  • Another participant agrees that the resistance is zero under ideal conditions, referencing a mathematical explanation involving a wire with zero resistance in parallel with a resistor.
  • A third participant mentions the existence of a short circuit, implying that the resistance of the wire connecting points A and B is effectively zero.
  • Some participants acknowledge the assumption of ideal conditions while noting that real transmission lines do have resistance.
Participants generally agree that under ideal conditions the resistance is zero, but there is acknowledgment of the complexities introduced by real-world factors, indicating that the discussion remains somewhat unresolved regarding practical applications.
The discussion does not fully address the implications of non-ideal conditions or the specific characteristics of the circuit components involved, leaving some assumptions unexamined.
R A V E N
I have one confusing issue to resolve:
What is the resistance between points [tex]A[/tex] and [tex]B[/tex] in simple system illustrated in attachment?Wouldn`t be logical to assume that it is [tex]0[/tex],as current strives to flow through path with lowest possible resistance,if I understood it correctly?
Yes,I know that real transmission lines have some resistance,but in network anaylsis their resistance is considered to be equal to zero.
You have a short circuit so what ever the resistance of the wire connecting point A and B.
CS
Yeah, it's zero assuming everything's ideal. Mathematically even, you have a wire ([tex]R=0[/tex]) in parallel with a resistor ([tex]R=R_0[/tex]). Then the parallel combination is:
[tex]R_{eq} = \frac{1}{ \frac{1}{0} + \frac{1}{R_0} } = \frac{1}{\infty + \frac{1}{R_0}} = 0[/tex]
I should probably have put some limits in there to be mathematically correct, but you get the idea.
Thanks to both of you!
  • · Replies 20 ·
  • · Replies 35 ·
12K
  • · Replies 25 ·
