| Thread Closed |
LR circuit, energy dissipated? |
Share Thread | Thread Tools |
| May8-08, 09:59 PM | #1 |
| May8-08, 10:26 PM | #2 |
Recognitions:
First find the current through the 6 ohm resistor in series with the inductor. Then when the switch is open, you can disregard the left hand side of the picture. The potential across the inductor is [tex]L\frac{dI}{dt}[/tex]. Use that along with the value of the resistors 6 and 12 ohms to construct an equation with KVL for the case when the switch is open.
Then solve that first order DE by separation of variables. Plug in the value of [tex]I_{0}[/tex] which is the initial current through the 6 ohm resistor in series with the inductor when the switch is just opened. You'll now have a decaying exponential function of t. That is the current through the circuit for t>0, assuming the switch is open at t=0. You can find the energy dissipated in the circuit by [tex]P = \frac{dE}{dt}[/tex] where P is power dissipated, E is energy dissipated. Using the expression for energy dissipated in the resistors, perform an integration from t=0 to t->infinity. You'll get 36 J. |
| May8-08, 10:35 PM | #3 |
Oh I see, I got 36 J. You can skip the integration using equivalent resistance to find the current in the middle branch, then do U = LI^2/2. This gives 36 J. Since the final current is 0, the energy must all be dissipated.
| Thread Closed |
| Thread Tools | |
Similar Threads for: LR circuit, energy dissipated?
| energy dissipated from a wire | Introductory Physics Homework | 2 | ||
| Rate at which energy is dissipated | Introductory Physics Homework | 2 | ||
| Energy dissipated by friction | Introductory Physics Homework | 1 | ||
| Energy Dissipated by Resistor | Introductory Physics Homework | 3 | ||
| power dissipated in circuit | Introductory Physics Homework | 3 | ||
