Understanding Volume Calculations for Rotational Solids
  • Thread starter Thread starter RedBarchetta
    Calculus Volume
The discussion focuses on calculating the volume of solids of revolution using the cylindrical shells and discs methods. Specifically, it addresses the volume of the solid formed by rotating the region bounded by the curves x=4+(y-3)² and x=8, as well as the volume from the curves y=-x²+9x-18 and y=0. Participants express confusion regarding the setup of integrals and the interpretation of variables when rotating around the x-axis. Ultimately, the importance of correctly identifying the radius, height, and thickness in the context of the cylindrical shell method is emphasized.
  • Understanding of volume calculations for solids of revolution
  • Familiarity with the cylindrical shells method
  • Knowledge of the discs method for volume calculation
  • Proficiency in using TI-83 graphing calculator for function entry
  • Learn how to set up integrals for cylindrical shells in calculus
  • Study the discs method for calculating volumes of solids of revolution
  • Practice graphing functions and identifying intersections using TI-83
  • Explore advanced integration techniques for complex volume problems
Students and educators in calculus, particularly those focusing on volume calculations for solids of revolution, as well as anyone seeking to improve their understanding of integral setup and function manipulation in mathematical contexts.
RedBarchetta
1.Consider the given curves to do the following.
x=4+(y-3)[tex]^{2}[/tex], x=8
Use the method of cylindrical shells to find the volume V of the solid obtained by rotating the region bounded by the given curves about the x-axis. Sketch the region and a typical shell.
I'm lost on x being a function of y. How do you even enter these into a TI-83? Is there any way to make these easier?
Here's another one I've been working on that has caused me problems.
_________________________________________________________________
2.The region bounded by the given curves is rotated about the x-axis.
y=-x[tex]^{2}[/tex]+9x-18
y=0
Find the volume V of the resulting solid by any method.
First I graphed it:
htp://img377.imageshack.us/img377/3471/6338ol4.png (Just add another t in http)
2 pi r h dr
I set up an integral. I get confused on determining the radius and height. If I'm rotating around the x-axis, I'm using y's. So, the radius should be y since it's centered around the y-axis. Then what is the shell height? The points at which the parabola crosses the curve are at x=3 and 6. So the shell height should be 6-y, but I think it should be where x = the equation.
But when I tried to single out x in the equation to get y as a function of x in y=-x[tex]^{2}[/tex]+9x-18, I couldn't calculate it.
Discs method
The area of one disc:
A(x)=[tex]\pi[/tex] * (-x[tex]^{2}[/tex]+9x-18)[tex]^{2}[/tex]
So the integral is
[tex]\pi[/tex] times the integral of (-x[tex]^{2}[/tex]+9x-18)[tex]^{2}[/tex] dx
Now the limits of integration should be from 3 to 6. I then integrated, plugged in the answer to my homework application which prompted me with a predictable "wrong" result. I've had no problems integrating, as I've completed 85% of my homework, but I have a hard time setting these problems up. Especially these odd-ball problems.
I'm sorry for my vague descriptions. It's hard to describe some of these things over the net. I appreciate any help. Thank you! :smile:
Hi RedBarchetta! :smile:
You can always change any variable letter into any other letter … provided, of course, you remember to change them back at the end!
Just interchange x and y, to give y = 4+(x-3)², y=8. :smile:
Forget the word "height" … you need the area of each shell, and the thickness of each shell.
Then you integrate over the thickness … sometimes it's height, sometimes it's radius, sometimes … :confused:
In this case, the thickness is not x, but dx.
Just think of it as "thickness", and you won't be confused! :smile:
But when I tried to single out x in the equation to get y as a function of x in y=-x+9x-18, I couldn't calculate it.
Sorry … I don't understand this … y is a function of x. :confused:
Show us your working on the integral, and then we can see where the mistake is. :smile:
Thanks for the help Tiny-Tim! I figured both of these out now. :approve:
  • · Replies 20 ·
