How Does Rotating a Polaroid Affect Light Intensity?
  • Thread starter Thread starter fionamb83
    Polarization
The discussion revolves around the effect of rotating a polaroid filter on light intensity, specifically using Malus' Law to analyze the changes in intensity when one polaroid is rotated by 30 degrees.
  • Participants initially explore the relationship between angle and intensity, with one attempting to use an incorrect equation. Questions arise regarding the definitions and relationships of variables in the context of the problem.
Some participants have identified the correct application of Malus' Law, while others are clarifying terminology and relationships between intensity and amplitude. There is an ongoing exploration of the mathematical expressions involved.
Participants are discussing the implications of rotating the polaroid and the assumptions related to the angles involved. There is mention of confusion regarding the terms used in the equations, particularly between intensity and amplitude.
fionamb83
Two sheets of polaroid are oriented so that there is a maximum transmission of light. One sheet is now rotated by 30 degrees, by what factor does the light intensity drop?
OK, the only equation I could think to use is tanB = N1/N2 but it doesn't seem to work.
the answer is 0.75 I just can't seem to get there.
Any help would be GREATLY appreciated.
Define the terms in this equation: what exactly are B, N1, N2, and how do they relate to the problem you've quoted?
Got it!
I feel silly! I realize equation I was trying to use was wrong. I solved it using Malus' Law
intensity after = Intensity before*cos^30
Thanks for the quick reply tho.
Malus' Law is spot on. The intensity is greatest when angle=0deg, zero when angle=90 deg. The cos(angle) function fits the bill, especially as the situation is a rotation.
Sorry, in the above post I should have said amplitude not intensity.
fionamb83 said:
... Malus' Law
In the above did you mean [tex]I = I_0 \sin 30^o[/tex] or [tex]I = I_0 \sin^2 30^o[/tex] ?
[tex] I = I_0 \cos^2 30^o[/tex]
From Cutnell, Physics
[itex]E=E_0 cos(30)[/itex] where [itex]E[/itex] is the field in Volts/m.
Power (intensity) is proportional to [itex]E^2[/itex], which in turn is proportional to [itex]I^2[/itex] (current squared).
[tex]\frac{I}{I_0}=\frac{E^2}{E_0^2}=\frac{(E_0 cos(30))^2}{E_0^2}=cos^2(30)=0.75[/tex]
[n.b. "I" for intensity is not current - I hope that isn't too confusing]
Regards,
Bill
  • · Replies 25 ·
9K
