What are the meter readings in the circuit?
  • Thread starter Thread starter looi76
    Circuit Meter
The discussion focuses on calculating meter readings in a circuit using Ohm's Law (V = IR) and the equivalent resistance of resistors in parallel. The user calculated the currents A_1, A_2, and A_3 as 0.16A, 45A, and 30A respectively, based on a voltage of 12V and resistances of 75Ω, 20Ω, and 30Ω. However, there is confusion regarding the total equivalent resistance of the circuit, which should be calculated as 25Ω for the resistors in parallel. The correct formula for equivalent resistance in parallel is also sought.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of calculating equivalent resistance for resistors in parallel
  • Basic circuit analysis skills
  • Familiarity with electrical units such as volts, amperes, and ohms
  • Study the formula for equivalent resistance in parallel circuits
  • Learn how to apply Ohm's Law in complex circuits
  • Explore circuit simulation tools like LTspice for practical applications
  • Review examples of current calculations in parallel resistor configurations
Students studying electrical engineering, hobbyists working on circuit projects, and anyone interested in understanding current flow in electrical circuits.
looi76
http://img372.imageshack.us/img372/8240/1005200803ki4.png
What are the meter readings in the circuit on the top?
[tex]V = IR[/tex]
[tex]I = \frac{V}{R}[/tex]
[tex]A_2 = \frac{12}{\frac{20}{75}} = 45A[/tex]
[tex]A_3 = \frac{12}{\frac{30}{75}} = 30A[/tex]
[tex]A_1 = \frac{12}{75} = 0.16A[/tex]
Are my answers correct?
I don't think your answers are correct. What is 75? Is it supposed to be total equivalence resistance of the circuit? If so, then that means the equivalent resistance of the resistors in parallel is 25 ohms, which is not right. What is the formula to find equivalent resistance of resistors in parallel?
35K
