Calculate G-Force & Deceleration for 4500kg Object Moving @ 5kph
The discussion revolves around calculating G-force and deceleration for a 4500kg object moving at 5kph that comes to a stop over a distance of 15cm. Participants are also exploring the impact force based on collision parameters.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate G-force and deceleration using given values and formulas. Some participants provide equations and calculations related to deceleration and force, while others question the accuracy of the numbers and units used.
Participants are actively engaging with the calculations, with some providing feedback on the math and questioning the units of measurement. There is a mix of attempts to clarify concepts and check the validity of the calculations presented.
There is mention of the original poster's urgency due to a professional situation, which adds a layer of importance to the accuracy of the calculations. Some participants express uncertainty about the definitions and units related to G-force and pressure.
exalto1
Hello...
If an object weighs 4500kg and travels @ 5kph (138cm/s) then stops in 15cm:
what is Gforce?
Decceleration?
Also, if object was stopped via a collision and if contact face is 100cmx15cm then what is impact force kg/sq.cm?
This information is really important to me for a professional argument that may save my job so ANY help/resources would be immensely appreciated.
Yes I did have an accident at work... :redface:
My only defence is going to have to be with cold science.
At 36, my algebra has rusted through as this is the first time I've had to find "x" so really need some whizzy help.
Thanks to anyone kind enough to help.
David
If something travels with the initial velocity V...
1.38m/s
and then stops over the distance L,.....
0.15m
then, assuming constant decelleration,
L = V^2/2a.........
0.15m=1.38m^2/2 x 6.348
0.15=1.9044/12.696
where V - initial velocity
a - absolute value of decceleration.
V^2 means "V squared"
From this, you can find
a = V^2/2L......... ...
a=1.38m^2/0.30m
a=6.348m/s
From the Newton's law,
a = F/M.......... ...
6.348m/s=28566n/4500kg
where F is the force that acted during the slowdown and M is the mass.
We then have
F = MV^2/2L.......
4500kg x 1.38m/s^2 /2 x 0.15m
4500 x 1.9044 / 0.30m
8569.8/0.30
F=28566n
Use M in kilograms, V in meters per second and L in meters. You'll get the force in Newtons.
I don't know what is Gforce.
Then the pressure is by definition the force divided by area. Diveide the force you've obtained by the area and you'll get pressure in Newtons per unit of area (whatever units you use)...
28566n/1.5m=19044n/sq m
or 1941.9kg/sq m
If someone could check this please I'd be grateful as I'm a little woozy with painkillers.
Thank you so very much.
Hi exalto1,
exalto1 said:
Then the pressure is by definition the force divided by area. Diveide the force you've obtained by the area and you'll get pressure in Newtons per unit of area (whatever units you use)...[/B]
or 1941.9kg/sq m
I'm not sure about these numbers. The area in square meters is .15 m^2.
G-force is usually the acceleration measured in units of g=9.8 m/s^2.
Hello alphysicist...
Are these figures better:P = 28566N/1500cm^2=19.044N/cm^2 or
P =~1.94kg/cm^2 or
P=~19400kg/m^2
P =~1.94kg/cm^2 or
P=~19400kg/m^2
Your math look okay to me, if those are the units you want. Using kg/cm^2 for the pressure reminded me that a unit that some people use for force is the gram-force. I would think that's probably what they meant by Gforce, so your choice of mass/area as the units for pressure would be what they wanted.
Thank you so very much Al
49K
