Is the Range of This Linear Transformation the Entire R2?
The linear transformation T: R^3 → R^2 defined by T(v_1, v_2, v_3) = (v_3 - v_1, v_3 - v_2) has a kernel that is one-dimensional, represented by the basis vector s(1, 1, 1). The dimension of the range of T is confirmed to be two, as the dimension of the kernel plus the dimension of the range equals the dimension of the domain (3). The range is a subspace of R^2, which inherently has only one two-dimensional subspace, indicating that the range of T is indeed the entire R^2.
  • Understanding of linear transformations in vector spaces
  • Familiarity with kernel and range concepts in linear algebra
  • Knowledge of basis vectors and their significance
  • Concept of dimensions in vector spaces
  • Study the properties of linear transformations in detail
  • Learn about the Rank-Nullity Theorem and its applications
  • Explore examples of kernel and range in different linear transformations
  • Investigate subspaces and their dimensions in R^n
Students and educators in linear algebra, mathematicians focusing on vector spaces, and anyone seeking to deepen their understanding of linear transformations and their properties.
oomba
T:[tex]{R^3 \rightarrow {R^2}[/tex] given by [tex]T(v_1,v_2,v_3) = (v_3 -v_1, v_3 - v_2)[/tex]
If linear, specify the range of T and kernel T
The attempt at a solution
Okay, I went ahead and tried to find the kernel of T like here:
[tex]\begin{align*}&v_3 - v_1 = 0\\<br /> &v_3 - v_2 = 0\end{align*}[/tex]
Thus, [tex]\begin{align*}&v_3 = v_1 \\<br /> &v_3 = v_2\end{align*}[/tex]
So choosing v3 as s gives the 1-D basis of W= s(1, 1, 1) **a column vector**
But I'm not entirely sure how to get the range. IF I did the kernel correctly, then that means the dimension of the range will be 2 as 2+1 = 3 (the dimension of the domain). But when I try to do the range, I get a 3-dimensional basis where v1,v2,and v3 are their own LI vectors as so:
(y1,y2) = s(1,1) + t(-1,0) + r(0,-1)
Any help?
Everything seems fine. So where's your difficulty?
You have correctly deduced that the range must have dimension 2 and you know that the range is a subspace of R2.
How many subspaces of dimension 2 do you think R2 has!
