A beam of red light has twice the intensity as a second bean of the same color
The problem involves comparing the intensity of two beams of red light, where one beam has twice the intensity of the other. The subject area relates to wave properties, specifically the relationship between intensity and amplitude.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the relationship between intensity and amplitude, referencing the proportionality of intensity to the square of amplitude. There are attempts to express the intensities in terms of amplitudes and questions about the correctness of these expressions.
Participants are exploring different interpretations of the relationship between the intensities and amplitudes. Some guidance has been offered regarding how to express the intensities in terms of amplitude, but there is no explicit consensus on the correct ratio of amplitudes yet.
There is a mention of homework constraints and the need to derive the ratio of amplitudes from the given intensities, which may influence the approach taken by participants.
looi76
A beam of red light has twice the intensity as a second bean of the same color. Calculate the ratio of the amplitude of wave.
[tex]intensity \propto (amplitude)^2[/tex]
[tex]1^{st} \mbox{ beam} = 2I[/tex]
[tex]2^{nd} \mbox{ beam} = I[/tex]
I don't know if this step is correct and I don't know what to do next?!
[tex]I_1=2 I_2[/tex]
[tex]\frac{I_1}{I_2}=2[/tex]
What can you do to the above relation (given your relevant equation) to convert it to a ratio of amplitudes?
Regards,
Bill
So, it will be [tex]1:4[/tex] ?
No, start off by expressing both intensities I = kA^2. Then compare the ratio of each amplitude to the other.
No. Try what Defennder suggested to see why.
Regards,
Bill
9K
