Differential equation questions, rate of change
The discussion revolves around a differential equation related to the rate of change of the radius of a circle formed by oil spreading in water over time. The problem involves two observers proposing different models for the rate of increase of the radius, with specific conditions provided for the initial state.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the formulation of differential equations based on the proposed models, with attempts to derive constants and solve for the radius over time. Questions arise regarding the separation of variables and the integration process necessary to find the radius.
Some participants have successfully identified the differential equations and constants, while others express uncertainty about the integration process needed to find the radius. There is an ongoing exploration of methods to solve the equations, with some guidance offered on integrating and separating variables.
Participants are working under the constraints of homework rules, which may limit the extent of assistance provided. The discussion includes varying interpretations of the problem setup and the assumptions made by the observers regarding the rate of change.
AdamNailor
Hello and greetings everyone.
1. A quantity of oil is dropped into water. When the oil hits the water it spreads out as a circle. The radius of the circle is r cm after t seconds and when t = 3 the radius of the circle is increasing at the rate of 0.5 centimetres per second
One observer believes that the radius increases at a rate which is proportional to [tex]\frac{1}{t+1}[/tex]
i) Write down the a differential equation for this situation, using k as a constant of proportionality.
ii) Show that k = 2
iii) Calculate the radius of the circle after 10 seconds according to this modelAnother observer belives that the rate of increase of the the radius of the circle is proportional to [tex]\frac{1}{(t+1)(t+2)}[/tex]iv) Write down a new differential equation for this new situation. Using the same initial conditions as before, find the the new value for the constant
v) Hence solve the differential equation
vi) Calculate the radius of the circle after 10 seconds according to this model.
2. ?
I'm pretty sure I can do the first two, i am getting stuck on part iii) however. I may beable to do the rest by myself after this is sorted out, but thought i would post the full Question just incase.
i) [tex]\frac{dr}{dt}=\frac{k}{t+1}[/tex]
ii) 0.5 = k/(3+1) so, k = 2
iii) [tex]\frac{dr}{dt}=\frac{2}{t+1}[/tex]
so... [tex]\frac{dr}{dt}=\frac{2}{11}[/tex] ??
Then i really don't have a clue what to do. I don't know how to separate the r from the dr/dt to find the radius form this relationship.
Thanks in advance. Adam.
wait! the latex didn't work, i should have previewed first. I'll just edit it...
in order to solve for the radius you need to solve the differential equation. try separation of variables.
ii) Show that k = 2
2. ?
Good!
so... [tex]\frac{dr}{dt}=\frac{2}{11}[/tex] ??p=
No, that's dr/dt when t= 10. As the problem says, you need to solve the differential equation.
If dr/dt= 2/(t+1) then dr= (2/(t+1))dt. It's that easy!
HallsofIvy said:
Good!
Thanks. I had a mental block remembering that to solve differential equations you have to integrate (kind of fundamental, i know!)
so...
dr= (2/(t+1))dt => r = 2 ln (t+1) + c
t=0, r=0 => c=0
When t = 10, r = 2ln11 = (approx) 4.796
That agrees with the answer in the book. cheers.
ii) Show that k = 2
2. ?
Thanks in advance. Adam.[/QUOTE
How about placing all terms in r with dr and all terms in t with dt and integrate both sides? Don't forget the constant and substitute given values to calculate the relation.
Could you E-Mail me the question at fayadwali@hotmail.com, and I'll send you the entire result. I can't understand the terms such as ...text/ etc.
  • · Replies 30 ·
