Thread Closed
Just want to clear this up
Share Thread
Apr30-04, 03:56 PM   #1
Is [tex]\frac {1}{\infty} = 0[/tex] , or is it just infinitely close to 0?
PhysOrg.com mathematics news on PhysOrg.com
>> Pendulum swings back on 350-year-old mathematical mystery
>> Bayesian statistics theorem holds its own - but use with caution
>> Math technique de-clutters cancer-cell data, revealing tumor evolution, treatment leads
Apr30-04, 03:58 PM   #2
Recognitions:
= is correct, the other alternative is not too meaningful, unless you get involved with non-standard analysis.
Apr30-04, 04:05 PM   #3
Quote by mathman
Unless you're using non-standard analysis I don't think the statement [itex]\frac{1}{\infty}=0[/itex] is even meaningful.
Apr30-04, 04:08 PM   #4
Recognitions:
Gold Membership Gold Member
Well, you could say 1/x -> 0 as x tends to infinity (though that obviously doesn'; mean 1/inifnity = 0 especially when infinity isn't even a number).
Apr30-04, 04:09 PM   #5
Lets say there is 1 unit of something in an infinitely large area...then would you say = ? Because then that says that the unit doesn't even exist...
Apr30-04, 04:48 PM   #6
Recognitions:
No in that situation all we would be saying is that it would be meaningless to talk about the ratio of the area to the unit area.
Apr30-04, 10:00 PM   #7
No it isn't...Because that unit DOES exist. But by saying 1/inf = 0...we say it is non-existant. In the same way, human population with respect to time would be 0 if the above statement were true. This is not so...
Apr30-04, 10:09 PM   #8
Recognitions:
Retired Staff Staff Emeritus
1/∞ doesn't have a "standard" meaning; in some systems where infinite numbers are defined, division doesn't exist. In some others, 1/∞ is some infinitessimal positive nonzero number. In others, 1/∞=0.
If you're thinking of ∞ as that "big number that sits at the positive end of the real numbers", then you probably mean to use the extended real numbers, where 1/∞ is defined to be equal to zero.
Apr30-04, 11:43 PM   #9
Mentor
In my books when infinity is defined as an extension to the Real number line, operations on infinity are also defined, included with these definitions is:
[tex] \frac 1 \infty = 0 [/tex]
This is a very specific definition for a very specific application ie the real numbers. If you attempt to apply this definition out of context your results may vary.
May1-04, 08:22 PM   #10
I always thought it meant infinitely close to zero, and that’s why the delta at the end of an integral doesn’t yield zero results, because the delta doesn’t actually = zero, just something infinitely small.
Thread Closed
Similar Threads for: Just want to clear this up
Thread Forum Replies
how to make clear ice.clear ice General Physics 17
Okay, clear this up for me General Astronomy 21
no clear on concept Introductory Physics Homework 3
Clear Channel.... Current Events 61
