Equation of Plane through M(2,3,1) and Line: Solved with Step-by-Step Guide
  • Thread starter Thread starter Physicsissuef
    Plane
The problem involves finding the equation of a plane that passes through a specific point M(2,3,1) and a line defined by two equations. The subject area includes concepts from linear algebra and geometry, particularly focusing on planes and lines in three-dimensional space.
  • Participants discuss the use of cross products to find the normal vector to the plane. There are questions about how to proceed after finding the line's equation and how to apply the normal vector in the context of the plane's equation.
Some participants have offered guidance on using the cross product to find the normal vector and how to substitute the given point into the plane equation. There is an ongoing exploration of the implications of the line being contained within the plane and the conditions for parallel planes.
There are mentions of potential confusion regarding the terminology used for normals and the conditions for parallel planes. Additionally, a correction was made regarding the line's equations provided in the initial post.
Physicsissuef
Find the equation of the plane which passes through M(2,3,1) and the line
[tex]\left\{\begin{matrix}<br /> 2x-y+3z-1=0 & \\ <br /> 5x+4y-z-7=0 & <br /> \end{matrix}\right.[/tex]
[tex]\frac{x-x_1}{\begin{vmatrix}<br /> B_1 & C_1\\ <br /> C_1 & C_2<br /> \end{vmatrix}}=\frac{y-y_1}{\begin{vmatrix}<br /> C_1 & A_1\\ <br /> C_2 & A_2<br /> \end{vmatrix}}=\frac{z-z_1}{\begin{vmatrix}<br /> A_1 & B_1\\ <br /> A_2 & B_2<br /> \end{vmatrix}}[/tex]
first I find the equation of the line:
[tex]\frac{x}{-1}=\frac{y+7}{-5}=\frac{z+3}{-3}[/tex]
What should I do next?
Are you familiar with cross products? (You must be, to some extent, as you have posted determinants. A solution of this form I have never seen before.)
If yes, then [tex]N1 \\ X \\ N2[/tex] will be the normal to your plane, where N1 and N2 are the normals to the lines given.
[itex]n_1 x n_2[/itex] will give me vector perpendicular to this ones, but how it will help me?
from that, you will have a, b, and c of the following equation for a plane.
[tex]a(x-x_{0})+b(y-y_{0})+c(z-z_{0})=d[/tex]
In other words, you will have the normal to the plane you're trying to solve for. Substitution of the point they give you will solve it.
[tex]n_1 x n_2=(-1,-5,-3)[/itex]<br /> <br /> A(x+1)+B(y+5)+c(z+3)=D<br /> <br /> Hmm... And what about x,y,z, should I substitute for M?[/tex]
Unfortunately, any line, R3 has an normals in an infinite number of directions- it doesn't make sense to talk about "the" normal to a line.
Choose any two points on the line. For example, if you choose x= 0, you can solve the two equations 2(0)-y+3z-1=0 and 5(0)+4y-z-7=0 for y= 2 and z= 1: (0, 2, 1) is on the line. If you take x= 1, you can solve 2(1)- y+ 3z- 1= 0 and 5(1)+ 4y- z- 7= 0 for y= -23/11 and z= -2/11. The cross product of the vectors from (2, 3, 1) to those points will give you the normal to the plane.
I retract having said 'normals' to the line. I got 'normal-happy' , what with the terminology for planes.
But the plane don't necessarily need to intersect the line in 2 points. It can intersect it in one point...
The plane intersects the line at an infinite number of points, i.e. the line is contained in the plane.
Otherwise, you would need more information than you are given to determine the plane uniquely.
What plane are you talking about? You were told to find the plane that contains that line. Every point on the line is in that plane.
Yes, sorry. My fault.
Will it be correct if I show it like this:
[tex]a \circ n=0[/tex]
[tex](a_1,a_2,a_3) \circ (A,B,C)=0[/tex]
So one of the conditions is:
-A-5B-3C=0
the second condition is:
2A+3B+C+D=0
and the third condition:
0*A-7B-3C+D=0
[tex]\left\{\begin{matrix}<br /> -A-5B-3C=0 & \\ <br /> 2A+3B+C+D=0 & \\ <br /> -7B-3C+D=0 & <br /> \end{matrix}\right.[/tex]
The result is:
[tex]-5x-y-7=0[/tex]
right?
Just to mention that in the first post the line is:
[tex]\left\{\begin{matrix}<br /> x+y-2z+1=0 & \\ <br /> 2x-y+z-4=0 & <br /> \end{matrix}\right.[/tex]
Sorry, for mistake, I type the wrong line...
And can I ask you something?
Two planes to be parallel, must this condition be satisfied?
[tex]A_1x+B_1y+C_1z+D=0[/tex]
[tex]A_2x+B_2y+C_2z+D=0[/tex]
[tex]\frac{A_1}{A_2}=\frac{B_1}{B_2}=\frac{C_1}{C_2}[/tex], since in my book doesn't look like that...
  • · Replies 36 ·
