Methanol medium pressure pump needed
The discussion centers on the need for a methanol medium pressure pump capable of handling temperatures around 140°F, flow rates of 1 to 2 gallons per minute (gpm), and pressures between 150 to 200 psi. Recommendations include exploring large peristaltic pumps and specific products such as those from URD USA and AEM's Universal Water-Alcohol Injection Kit. A datasheet from Eccentric Pumps is also referenced, which may meet the required specifications, although chemical compatibility needs to be verified.
  • Understanding of pump specifications including flow rate, pressure, and temperature.
  • Familiarity with peristaltic pump technology and its applications.
  • Knowledge of chemical compatibility for pump materials with methanol.
  • Basic project management skills for sourcing and evaluating pump options.
  • Research large peristaltic pumps suitable for methanol applications.
  • Investigate the chemical compatibility of materials used in pumps with methanol.
  • Review the datasheet from Eccentric Pumps for detailed specifications.
  • Explore alternative pump solutions that can handle dry running conditions.
Engineers, project managers, and technicians involved in fluid handling systems, particularly those working with methanol or similar chemicals.
BernieM
I have a project that i am doing that requires that i pump methanol at a temperature of about 140F at a volume of about 1 to 2 gpm and a pressure of around 150 - 200 psi. It must be capable of 'run dry' by which i mean that it may not always have fluid to pump. Can anyone give me a lead on a pump that will fill this need?
How about something like this:
http://www.urdusa.com/product_info.php?cPath=17_89&products_id=124806052
Or maybe the pump out of this kit if you can find it:
http://www.streetperformance.com/part-showcase/aem-advanced-engine-management-inc/6016-run-big-boost-on-pump-gas-with-aems-universal-water-alcohol-injection-kit.html
You'll probably have to go with a large peristaltic pump. I must say that the flow and higher pressure that you're looking for may make it tough to find in a single package.
Try taking a look here:
http://www.eccentricpumps.com/docs/EccentricPumps-SLP058DataSheet.pdf
This one I came across will do the flow and the pressure. I didn't look into chemical compatibility though.
  • · Replies 16 ·
  • · Replies 116 ·
