Lightwave moving towards/upwards curvature
  • Context: Graduate
  • Thread starter Thread starter Domenicaccio
    Curvature
The discussion revolves around the behavior of lightwaves in the presence of gravitational fields, particularly focusing on how light is affected when traveling towards or away from a massive object. Participants explore concepts such as gravitational time dilation, the curvature of spacetime, and the implications of these effects on the speed and trajectory of light.
  • Some participants express confusion about how light behaves when it travels directly towards a massive object, questioning whether it can be accelerated or slowed down in such a scenario.
  • Gravitational time dilation is mentioned as a factor that could affect the perception of light's speed and behavior in a gravitational field.
  • One participant suggests that light moving through a gravitational field behaves similarly to light moving through a medium with a lower refractive index, leading to bending of the lightwave.
  • Another participant notes that while light's speed remains c locally, the coordinate speed of light may appear to slow down as it approaches a gravitational mass.
  • The equivalence principle is referenced, indicating that free-falling observers measure the speed of light as constant in their vicinity, despite the effects of gravity.
  • There is a discussion about the implications of light traveling to and from a gravitational body, including the time taken for signals to reflect off surfaces and the potential for light to take a "detour" through an additional dimension.
  • One participant proposes an analogy of an imaginary medium surrounding a gravitational body that increases in density towards the surface, affecting the light's speed.
Participants express various viewpoints on the effects of gravity on light, with no consensus reached on the specifics of how light behaves when approaching a massive object. The discussion remains unresolved regarding the implications of gravitational time dilation and the nature of light's interaction with gravitational fields.
Limitations include the lack of specific formulas to quantify the effects discussed, as well as the dependence on interpretations of gravitational effects and the nature of spacetime. The discussion also highlights the complexity of reconciling different models and analogies used to explain light behavior in gravitational fields.
Domenicaccio
I don't know why this question puzzles me...
I believe I can understand the general idea that a lightwave moving in the vicinity of a source of gravity would be deflected by it, as in the "rubber sheet" model, and would curve slightly towards the mass.
But is this also valid when the light is traveling along a direction that directly passes through the mass?
It would seem impossible for a lightwave going straight into a large mass to be accelerated from it, since it cannot accelerate further beyond c (e.g. a ray of light from sun to earth).
And at the same time it would seem impossible that the lightwave would be "slowed down" when moving straight away from the mass (e.g. an EM wave generated on Earth and sent to space).
So does the curvature have an effect only to the lightwave's trasversal movement?
But OTOH gravity/curvature does indeed have an effect on anything non-relativistic (a "slow" mass) in a radial direction.
How do you link all these things together?
Any guess?
gravitational time dilation.
Could you please put it down in formulas?
If the lightwave goes towards a huge mass, what would an observer on the lightwave register (in terms of time dilatation) and what would instead another observer looking at the lightwave from afar see happen to the wave?
i don't have any formulas. if a light wave moves through a gravitational field then it should be slowed by gravitational time dilation. that should have the same effect as moving through a material with lower refractive index. the light wave should be bent.
Ok but what if the light wave travels TOWARDS the mass?
it would be slowed but nobody there would notice since they would also be slowed. locally, its speed would still be c.
also i think space itself is stretched so there is more space for the light wave to cover.
Over a large scale a light wave slows down as it travels towards a gravitational mass. That is called the coordinate speed of light. On a small scale gravitational time dilation and length contraction ensure an observer anywhere in the gravitational field measures the speed of light as c in their immediate vicinity. The equivalence principle also makes it clear that a free falling observer will also see the speed of light as constant in his immediate vicinty. The constant local speed of light according to any observer accelerating or not is an important concept in general relativity.
However...
If a mirror is placed on the surface of a gravitational body a signal sent from an observer 10 light seconds above the surface will take more than 20 seconds to travel down and reflect off the mirror and return to the observer. Some people like to think the light has taken a detour through an additional invisible dimension to account fo the extra time taken. This is akin to the deformed rubber sheet analogy. The trouble with the additional dimension explanation is that it has difficulties explaining why the two way trip takes less than 10 seconds according to an observer on the surface of the body. The same logic implies that the photon has somehow taken a shortcut through the addititional dimension. A possibly better analogy is that the gravitaional body is surrounding by an imaginary medium that increases in density towards the surface of the body. It is easy to imagine that the light slows down as the density (or the refractive index) of the imaginary medium increases. Of course all the above implies that the photon accelerates as it moves away from a gravitational body (on a large scale) which is probably exactly the opposite of what you would assume it would do.
  • · Replies 32 ·
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 16 ·
