Average force/impulse/collision problem
  • Thread starter Thread starter NoPhysicsGenius
    Average
The discussion centers on a physics problem involving a collision between two ice skaters, each with a mass of 75 kg. Initially, one skater moves at 10 m/s, while the other is stationary. After a perfectly inelastic collision, both skaters move together at 5 m/s. The average force experienced during the collision is calculated to be 3750 N, which is below the threshold of 4500 N, indicating that no bones break. The error in the initial calculation stemmed from incorrectly assessing the change in momentum for the entire system instead of focusing on one skater.
  • Understanding of momentum conservation principles
  • Familiarity with perfectly inelastic collisions
  • Knowledge of impulse-momentum theorem
  • Basic algebra for solving physics equations
  • Study the impulse-momentum theorem in detail
  • Learn about perfectly inelastic collisions and their characteristics
  • Explore examples of momentum conservation in different systems
  • Practice calculating average force in collision scenarios
Students studying physics, particularly those focusing on mechanics and collision problems, as well as educators looking for illustrative examples of momentum conservation and impulse calculations.
NoPhysicsGenius
[SOLVED] Average force/impulse/collision problem
A 75-kg ice skater moving at 10 m/s crashes into a stationary skater of equal mass. After the collision, the two skaters move as a unit at 5 m/s. The average force that a skater can experience without breaking a bone is 4500 N. If the impact time is 0.1 s, does a bone break?
[tex]\overrightarrow{I} = \Delta \overrightarrow{p} = \overline{F} \Delta t[/tex]
[tex]\Rightarrow \overline{F} = \frac{\Delta \overrightarrow{p}}{\Delta t}[/tex]
Also ...
[tex]\Delta p = p_f - p_i = m_1v_{1f} + m_2v_{2f} - m_1v_{1i} - m_2v_{2i}[/tex]
However, for a perfectly inelastic collision, [itex]v_f = v_{1f} = v_{2f}[/itex]. Therefore ...
[tex]\Delta p = (m_1 + m_2)v_f - m_1v_{1i} - m_2v_{2i}[/tex]
The answer given in the back of the book says that the average force is 3750 N so that no, bones do not break.
[itex]m_1[/itex] = moving skater; [itex]m_2[/itex] = stationary skater
[tex]\overline{F} = \frac{(75 kg + 75 kg)(5 m/s) - (75kg)(10m/s) - (75kg)(0 m/s)}{0.1s} = 0 N[/tex]
What have I done wrong? Thank you for your help.
Here you have calculated the change in momentum of the entire system (i.e. the change in momentum of both skaters), which is zero as it should be since momentum is conserved!
Instead, what you need to calculate is the change in momentum of one of the skaters.
Wow ... That was really foolish of me! Thank you!
23K
