Integral Proof: u^2-a^2 | Detailed Explanation
  • Context: Undergrad
  • Thread starter Thread starter inquisitive
    Integral
The discussion revolves around the integral of the function \( \int \frac{du}{u^2-a^2} \) and seeks a detailed proof of its solution, which is proposed to be \( \frac{1}{2a} \ln \frac{u+a}{u-a} + C \). Participants explore various methods of proving this integral, including trigonometric substitution and partial fraction decomposition.
  • One participant requests a detailed proof of the integral and its solution.
  • Another suggests verifying the solution by taking the derivative of the right-hand side.
  • A different approach is proposed using the substitution \( u = a \sec y \), leading to a transformation of the integral into a different form.
  • Partial fraction decomposition is mentioned as an alternative method for solving the integral.
  • A participant expresses gratitude for the proposed solutions but notes difficulty in reaching the final form of the answer after using trigonometric substitution.
  • There is a mention of differentiating the proposed solution as a valid method to prove it is an anti-derivative.
Participants do not reach a consensus on the best method to prove the integral, as multiple approaches are discussed, and some participants express uncertainty or difficulty with specific steps in the solutions.
Some participants note challenges in manipulating logarithmic properties and algebraic forms to arrive at the desired solution, indicating potential limitations in their understanding or execution of the methods discussed.
This discussion may be useful for students or individuals seeking to understand various methods of solving integrals, particularly in the context of calculus and mathematical proofs.
inquisitive
Anyone please help I need a detailed proof of this integral
[itex] \int du/(u^2-a^2) = (1/2a) ln (u+a)/(u-a) + C[/itex]
haveyou tried taking the derivative of the RHS?
You get the answer by taking u=a*sec y =>y=arcsec u/a(arcsec-sec inverse)
=>du=a sec y tan y dy
Therefore I=integral[(a sec y tan y dy)/a^2 tan^2 y]
=>(sec y dy)/(a tan y)
=>cosec y dy /a
=>ln(cosec y-cot y)/a
then just substitute value of y to get the answer
You could also do this by partial fraction decomposition.
You need to show that you've attempted the problem.
Thanks guys...
The solution swapnilster proposed is correct. I also did his solution before. But after the trigonometric substitution I was stuck at the answer
[itex] <br /> \frac{1}{2}ln \frac{(u+a)}{\sqrt{u^2-a^2}}+ C<br /> [/itex]
This is where I started to need some help from you guys. But after some time I realized to arrive to the form
[itex] <br /> \frac{1}{2a}ln \frac{u+a}{u-a}+ C;<br /> [/itex]
I just need to put the (u+a) term inside the radical and apply some algebra and properties of logarithms. But anyway, thanks again guys.
As pointed out by MathWonk, a perfectly valid method of proving that a given function is an anti-derivative is to differentiate it. That, typically, is easier than trying to integrate "from scratch".
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 17 ·
