| Thread Closed |
[SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy |
Share Thread |
| May14-08, 05:45 AM | #1 |
I'm pretty sure I did this one wrong, =( please help clarify?
8. At the Calgary Stampede, you can win a prize if the bell rings when you strike a wooden block with a 10.0-kg hammer. The block is at one end of a lever. The other end of the lever drives a 2.0-kg metal bar up a slide to ring the bell 9.0 m above. What is the minimum speed the hammer must be swung to make the bar hit the bell? Assuming there are no energy losses, the energy required to be transmitted to the 2.0-kg bar can be calculated and used as the kinetic energy required for the hammer. Ek = 1/2mv^2 Ep = mgh Em = Ep + Ek v = √[(2•Ek)/m] m1 = 10.0kg m2 = 2.0kg mt = m2 + m1 = 12.0kg D = 9.0m Ep = mgh = (2.0kg)(9.0m)(9.81m/s^2) = 176.58 J Hammer: h = 0m v = √[(2•Ek)/m] + mgh = √[(2•176.58J)/10.0kg] + (10.0kg)(9.81m/s^2) = 104.042726646919 v = 1.0x10^2 m/s The hammer should have a velocity of 1.0x10^2 J when it hits the wooden block, causing 1.77x10^2 J of energy on the 2.0kg block. |
| May14-08, 05:56 AM | #2 |
| May14-08, 06:02 AM | #3 |
Thank you! 5.9 m/s sounds allot better than 104m/s haha!
| May14-08, 06:05 AM | #4 |
| Thread Closed |
Similar discussions for: [SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy
| HELP! ~ Mechanical Energy vs Potential Energy & Kinetic Energy | Introductory Physics Homework | 4 | ||
| Kinetic, potential and mechanical energy question. | Introductory Physics Homework | 4 | ||
| Transformation of Kinetic and Gravitational Potential Energy:Conservation of Energy. | Introductory Physics Homework | 9 | ||
| Mechanical Kinetic Energy vs Electrical Potential Energy | Introductory Physics Homework | 3 | ||
| thermal/mechanical/potential/kinetic energy help | Introductory Physics Homework | 1 | ||
