Definition of Curvature for Sphere in Relativistic Cosmology
  • Context: Graduate
  • Thread starter Thread starter maverick280857
    Curvature
The discussion revolves around the definition of curvature for a sphere in the context of relativistic cosmology, specifically referencing a formula from "An Introduction to Modern Astrophysics" by Carroll and Ostlie. Participants explore the implications of the formula involving measured and expected circumferences and area, as well as the significance of the Gaussian curvature in two-dimensional surfaces.
  • Vivek presents a formula for curvature involving the measured circumference, expected circumference, and expected area of a circle on a sphere, expressing uncertainty about its derivation.
  • Mentz114 suggests that the ant's path is not along a great circle, implying that the formula relates to the curvature of the sphere.
  • Vivek questions the role of the 6π factor and the relationship between the circumferences and area in the curvature expression.
  • Pete states that the relation presented is the Gaussian curvature for a two-dimensional surface, noting that Gaussian curvature is not defined for higher-dimensional spaces.
  • Some participants refer to external resources, such as Wikipedia, for derivations of Gaussian curvature, indicating a desire for deeper understanding.
  • A later reply suggests that the expression discussed may be a special case of a more general definition of curvature for two dimensions.
Participants express differing levels of understanding regarding the curvature formula and its derivation. There is no consensus on the clarity of the formula's components or their implications for curvature.
Participants note limitations in their understanding of the specific definition of curvature used in the context of the discussion, as well as the mathematical background required to fully grasp the concepts involved.
maverick280857
Hi.
I am reading "An Introduction to Modern Astrophysics" by Carroll and Ostlie, for a summer project. In section 27.3 (Relativistic Cosmology) the curvature of a sphere is given by
[tex]6\pi \frac{C_{exp}-C_{meas}}{C_{exp}A_{exp}}[/tex]
The situation is as follows:
Consider a sphere of radius R. An ant is moving on the sphere at a fixed polar angle [itex]\theta[/itex]. The ant measures the circumference [itex]C_{meas} = 2\pi R\sin\theta[/itex] whereas the expected value of circumference is [itex]C_{exp} = 2\pi D[/itex] where [itex]D = R\theta[/itex]. The expected area of the circle is [itex]A_{exp} = \pi D^2[/itex].
I am not sure how the above expression leads to the curvature of the sphere...
Any thoughts?
Thanks.
Cheers
Vivek.
My understanding of this is that the ant walks in a circle, not a great circle. In this case the expression you quote gives the curvature of the sphere. Imagine the ant walking is a circle on a flat surface, then let the flat surface curve. The ratio of the diameter to the radius changes.
Mentz114, thanks for your reply. I'm not clear about the way the curvature has been written in terms of the two circumferences and the area, and also the [itex]6\pi[/itex] factor. How does all that come in?
maverick280857 said:
Hi.
Any thoughts?
Thanks.
Cheers
Vivek.
That relation is the Gaussian Curvature for a two dimensional surface. Gaussian curvature is not defined for spaces higher than two.
Pete
maverick280857 , if you want a derivation, check out Wiki on 'Gaussian curvature'. There's even an expression in terms of Christoffel symbols.
Thanks, I'm still learning these things and I don't know much about them. The page you have referred to does not explain the origin of the particular definition of curvature used here. But I will keep looking.
Ok, so I guess its a special case of the expression given there, for 2 dimensions.
