Electron Precession versus Proton Precession in a Magnetometer?
The discussion centers on the reasons why electron precession is not utilized alongside proton precession in proton precession magnetometers. It is established that the magnetic moments of electrons are approximately 1000 times weaker than those of protons, resulting in a significantly weaker signal that is difficult to detect. Furthermore, the thermal motion of electrons exceeds their precession frequency, further diminishing their signal strength, making them impractical for use in magnetometry.
  • Understanding of proton precession magnetometers
  • Knowledge of magnetic moments and their significance
  • Familiarity with signal detection and noise analysis
  • Basic principles of electron behavior in magnetic fields
  • Research the principles of proton precession magnetometers
  • Explore the concept of magnetic moments in detail
  • Investigate signal-to-noise ratio optimization techniques
  • Learn about thermal motion effects on particle behavior in magnetic fields
Researchers, physicists, and engineers involved in magnetometry, as well as anyone interested in the comparative analysis of electron and proton precession in magnetic applications.
xerxes73
Hello,
Why is it that electron precession is not used in addition to proton precession in a proton precession magnetometer? It seems to me that when the frequencies are emitted as the protons precess that the electrons would do precessing at the same time and provide a secondary frequency to observe. Observing a second frequency would provide a better signal to noise for processing and perhaps may decay faster or slower providing a signal that is better at different times or different situations. I imagine there is a fundamental reason why this is not done but I can't find anything on the web that talks to this.
Thanks,
Xerxes73
The main reason why electron precession is not used in addition to proton precession in a proton precession magnetometer is because electron precession does not produce a significantly strong enough signal to be detected. The magnetic moments of electrons are about 1000 times weaker than those of protons, so the signal they produce is much smaller and harder to detect. Additionally, the thermal motion of electrons is often greater than the precession frequency, which further diminishes the signal strength.
  • · Replies 0 ·
