Thread Closed
A cylinder of electric field varying in time
Share Thread Thread Tools
May15-08, 04:28 AM   #1
Hi, I have this problem:
In empty space there is an infinite cylinder, with its axis parallel to z axis and radius a, filled with an eletric field of equation
[tex]\vec{E}(t) = E_0 e^{\beta t} \hat{z}[/tex]
Now I put a rectangular wire on the plane yz out of the cylinder of side l and b (l lies on the y axis) and the question is: which is the current on the wire?
I try to attack the problem in the straightforward way. So I try to solve Maxwell's fourth equation
[tex]\vec{\nabla} \times \vec{B} = \frac{1}{c} \partial_t \vec{E}[/tex]
and initially I thought that I had to compute the flux through the wire of the varying magnetic field I get.....but I realize that this is impossible because this equation is only valid inside the cylinder, where I have a varying electric field, and not outside where there is only empty space!!!
Could anyone help...please?!?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
May15-08, 06:24 AM   #2
pam
Use Ampere's law (with the displacement current) to get B(t) outside the cylinder.
May15-08, 12:12 PM   #3
What do you mean with Amperč's Law?? Maybe the fourth Maxwell's Equation?? This one?
[tex]\vec{\nabla} \times \vec{B} = \mu_0 \vec{J} + \frac{1}{c^2} \frac{\partial \vec{E}}{\partial t}[/tex]
And if I do?? The displacement current is zero outside the cylinder...
May15-08, 12:38 PM   #4
pam
Using Stoke's theorem, you can derive Ampere's law:
[tex]\oint{\bf dr}\cdot{\bf B}=\frac{1}{c^2}\int{\bf dS}\cdot\partial_t{\bf E}[/tex].
May15-08, 01:16 PM   #5
Ok...I get what you mean. So I choose a cylinder of radius r>a and height z, evaluate the flux of [tex]\frac{\partial \vec{E}}{\partial t}[/tex] and thanks to Ampere's Law this is equal to the path integral of B over a circle of radius r in the at height z parallel to xy plane. May I say that B is always tangential so the path integral is easy to evaluate?? If yes why?? I thought in analogy with the magnetic field generated by a wire...
Thank you
Ciao!!
May16-08, 06:29 AM   #6
pam
It is just like a wire, but it doesn't matter.
For the loop you have only B tangential enters the flux.
Thread Closed
Thread Tools
Similar Threads for: A cylinder of electric field varying in time
Thread Forum Replies
time varying e-field polarization Advanced Physics Homework 4
Distance-Varying Electric Field and Voltage of Parallel Plate Capacitors Introductory Physics Homework 4
superposition if time varying electric vectors Advanced Physics Homework 3
Electric Field outside a cylinder Introductory Physics Homework 50
Time-Varying Magnetic Field Advanced Physics Homework 2
