Calculating Minimum Distance between Elliptical Orbits | Orbital Distance Forum
  • Context: Graduate
  • Thread starter Thread starter Coelum
    Orbits
This discussion focuses on calculating the minimum distance between two non-interacting bodies on elliptical orbits, specifically using a numerical approach with the conjugate gradient method. The problem is framed as a minimization of a function with two variables in the domain [0,2*pi)*[0,2*pi). Key orbital elements required for the calculation include the semimajor axis (a), eccentricity (e), inclination (i), longitude of ascending node (L), and argument of perihelion (w). The provided algorithm iteratively refines the search for minimum distance using eccentric anomalies and Cartesian coordinates.
  • Understanding of elliptical orbits and their parameters (a, e, i, L, w)
  • Familiarity with numerical optimization techniques, specifically the conjugate gradient method
  • Basic knowledge of programming for implementing iterative algorithms
  • Proficiency in trigonometric functions and their application in coordinate transformations
  • Research advanced numerical optimization techniques for multidimensional minimization
  • Explore analytical methods for simplifying orbital mechanics problems
  • Learn about the implementation of the conjugate gradient method in programming languages like Python or MATLAB
  • Investigate the effects of orbital perturbations on distance calculations between celestial bodies
Astronomers, aerospace engineers, and computational physicists interested in orbital mechanics and distance calculations between celestial bodies.
Coelum
Forum,
I'm addressing the problem of computing the minimum possible distance between two non-interacting bodies on elliptical orbits. From a general point of view, it looks like a minimization problem of a function of two variables, e.g. in the domain [0,2*pi)*[0,2*pi). This problem can be numerically addressed in a standard fashion, e.g. by a conjugate gradient method. But I wonder if an analytical approach exists that can simplify the problem - maybe reducing it to unidimensional - and significantly speed-up the computation.
Astronomy news on Phys.org
Coelum said:
Forum,
For this problem, you don't need to know where the planet is in its orbit at any particular time, so you can ignore the epoch of mean anomaly and time of perihelion passage. But you do still need the other elements ( a, e, i, L, w ).
You probably know this method already, judging by what you wrote. I used the plain old peck-peck-peck method, except I added an outer loop for homing in on the part of the barnyard where the feed is the thickest. It might speed things up a little.
In the procedure below, for variables having two subscripts, the first subscript will designate which orbit (either 0 or 1) and the second subscript will designate either the beginning (0) or the end (1) of an eccentric anomaly search interval. For variables having only one subscript, the subscript will specify which orbit. All eccentric anomalies, and all other angles, are used only in radians.
a : semimajor axis
e : eccentricity
i : inclination
L : longitude of ascending node
w : argument of perihelion
BEGIN
u00 = 0
u01 = 2*pi
u10 = 0
u11 = 2*pi
drmin = 9.9E+99
drgrandmin = 9.9E+99
count = 0
Repeat
count = count + 1
du0 = (u01 - u00)/100
du1 = (u11 - u10)/100
u0 = u00 - du0
Repeat
u0 = u0 + du0
x0''' = a0 (cos u0 - e0)
y0''' = a0 sin u0 (1 - e0^2 )^0.5
x0'' = x0''' cos w0 - y0''' sin w0
y0'' = x0''' sin w0 + y0''' cos w0
x0' = x0''
y0' = y0'' cos i0
z0' = y0'' sin i0
x0 = x0' cos L0 - y0' sin L0
y0 = x0' sin L0 + y0' cos L0
z0 = z0'
u1 = u10 - du1
Repeat
u1 = u1 + du1
x1''' = a1 (cos u1 - e1)
y1''' = a1 sin u1 (1 - e1^2 )^0.5
x1'' = x1''' cos w1 - y1''' sin w1
y1'' = x1''' sin w1 + y1''' cos w1
x1' = x1''
y1' = y1'' cos i1
z1' = y1'' sin i1
x1 = x1' cos L1 - y1' sin L1
y1 = x1' sin L1 + y1' cos L1
z1 = z1'
dx = x1 - x0
dy = y1 - y0
dz = z1 - z0
dr = (dx^2 + dy^2 + dz^2)^0.5
If dr (is less than) drmin then
begin
drmin = dr
u0,min = u0
u1,min = u1
x0,min = x0
y0,min = y0
z0,min = z0
x1,min = x1
y1,min = y1
z1,min = z1
end
Until { u1 (is greater than) u11 } or { du1 (is less than) 1E-12 }
Until { u0 (is greater than) u01 } or { du0 (is less than) 1E-12 }
u00 = u0,min - du0
u01 = u0,min + du0
u10 = u1,min - du1
u11 = u1,min + du1
Q = abs(drgrandmin - drmin) / drmin
If drmin (is less than) drgrandmin then drgrandmin = drmin
Until { Q (is less than) 1e-12 } or { count (is greater than) 20 }
END.
Jerry Abbott
Jenab,
thanks for your reply. I'll check carefully your code.
Francesco
  • · Replies 17 ·
13K
