Maximum and Minimum Values of a Trigonometric Function
The discussion revolves around finding the maximum and minimum values of trigonometric functions, specifically (sin a)^4 - (sin a)^2 and sin x + cos x. Participants are exploring calculus concepts related to derivatives and critical points.
  • The original poster attempts to understand how to find maximum and minimum values using derivatives, questioning the correctness of their derivative calculation and seeking clarification on the process.
  • Participants discuss the implications of setting the derivative to zero to find critical points and the periodic nature of sine and cosine functions, raising questions about the range of values to consider.
  • Some participants suggest using the second derivative test to classify critical points, while others emphasize the importance of working in radians.
The discussion is active, with participants providing hints and guidance on the use of derivatives and critical points. There is an exploration of multiple interpretations regarding the periodicity of trigonometric functions and the implications for finding extrema.
Participants are navigating the transition from degrees to radians and discussing the periodic nature of sine and cosine functions, which affects the determination of maximum and minimum values across different intervals.
ritwik06
Find the maximum and minimum value of:
I am new to the world of calculus. I have just learned to evaluate the derivatives of functions. (*and nothing else- I am a high school student) For this function the derivative is
-sin 2a . cos 2a
Please tell me if I am right.
While teaching my teacher told me that we can obtain the maximum and minimum values of a function with the help of its derivative. Is it true?
If yes, please spare some time to tell me how is it possible. I know that the maximum and minimum values can be calculated by coverting this into a perfect square. But I wish to learn it through calculus, if possible.
Thanks!
regards,
Ritwik
Hi ritwik06! :smile:
ritwik06 said:
-sin 2a . cos 2a
Yes, that's fine! :smile:
The derivative is the rate at which the function increases.
At a maximum or minimum, the function has stopped increasing, so the derivative is zero. :smile:
ok. thanks a lot tim.
but the problem now is that if I put:
- sin 2a . cos 2a=0
the values of 'a' that are possible are:
0, 180 ,360, ...
45, 135, 225...
at which value will I get the maximum and at which value the minimum?
similarly if I want to fin th maximum and minimum of sin x+cos x
dy/dx=cos x - sinx
cos x - sin x=0
cos x=sin x
x=45, 225... (till what values of x should I limit myself??)
Do I need to check from [0,2*pi]?
Because after that. the values of the T-ratios repeat. Am I right?
The first thing you need to do is rewrite those x values in terms of radians rather than degrees!
And you had better learn to start thinking in terms of radians. For the functions sin(x) and cos(x), the "x" has to be interpreted in radians, not degrees.
Well, you will get an infinite number of local extrema, because the sin and cosine are periodic functions. That being said, half will be local maxima, and half will be local minima.
You have to use the second derivative test to determine whether each critical point represents a local minimum (second derivative > 0 at the x), a local maximum (second derivative < 0 at the x) or neither (second derivative = 0 at the x).
But yes, you will have to give your answer like...
f(x) = sin x
Maxima: 1/2 PI, 5/2 PI, 9/2 PI, ...
Minima: 3/2 PI, 7/2 PI, 11/2 PI, ...
(or)
Maxima: (4n-3)/2 PI, for all natural numbers n
Minima: (4n-1)/2 PI, for all natural numbers n
Hopefully that clarified what was being asked.
Welcome to PF!
Hi csprof2000! Welcome to PF! :smile:
Don't too much work … best just to give a hint and see if the OP can work out the rest themselves! :wink:
f(x) = sin x
(or)
Thanks A Lot!
