Graphing polar curves: limacon and 2 oddballs
This discussion focuses on graphing polar curves, specifically limacons and the conchoid of Nicomedes. The key formulas for determining the presence of inner loops in limacons are r=a±cosθ and r=a±sinθ, with examples showing that r=1+2cosθ has an inner loop while r=1.5+cosθ does not. The discussion also highlights the importance of understanding the symmetry of sine and cosine functions when selecting theta intervals for graphing. Additionally, it clarifies that for cardioids, an inner loop exists if a < b, while a = b results in a "dimple" and a > b indicates no loop.
  • Understanding of polar coordinates and polar equations
  • Familiarity with limacons and their properties
  • Knowledge of the symmetry of sine and cosine functions
  • Basic graphing skills for polar curves
  • Explore the properties of polar curves, focusing on limacons and cardioids
  • Learn about graphing techniques for polar equations using software like Desmos or GeoGebra
  • Investigate the conchoid of Nicomedes and its graphing characteristics
  • Study the implications of negative radius values in polar graphs
Mathematicians, educators, and students interested in advanced graphing techniques for polar curves, particularly those studying calculus or analytical geometry.
rocomath
I'm trying to find patterns for polar curves. I just reviewed and feel comfortable with taking advantage of symmetry, but I still have trouble with some type of curves.
Limacons: Two types
1) inner loop
2) no inner loop
Is there a general formula that tells me whether there will be an inner loop? [tex]r=a\pm\cos\theta[/tex] and [tex]r=a\pm\sin\theta[/tex]
[tex]r=1+2\cos\theta[/tex] inner loop
[tex]r=1.5+\cos\theta[/tex] no inner loop
I tried to find a pattern myself, but I didn't find one.
[tex]r=1+2\cos\theta[/tex] inner loop, testing if b=even
[tex]r=a+3\cos\theta[/tex] inner loop, testing if a=k, b=odd
Now the reciprocal curves threw me off. I had forgotten about the range of cosecant, which is [tex][1,\infty)U(-\infty,-1][/tex], and I looped my curve back inwards, which is incorrect.
In general, when I'm graphing polar. Sine is symmetric with the y-axis, so the values of theta that I choose are from [tex]-\frac{\pi}{2}\leq\theta\leq\frac{\pi}{2}[/tex], and Cosine is symmetric with the x-axis, so I use [tex]0\leq\theta\leq\pi[/tex].
Now my main problem:
[tex]r=\csc\theta+2[/tex] (conchoid of Nicomedes)
Cosecant is also symmetric with the y-axis, so I choose my theta interval to be [tex]-\frac{\pi}{2}<\theta<\frac{\pi}{2}[/tex].
I don't think of it as a general formula so much as a method for sorting out what the curve will do.
Plot each function on a graph of r versus [tex]\theta[/tex] over a full cycle
The first of these has a radius function which ranges from 3 to -1. The fact that the radius is negative in part of the second and third quadrants tells you there will be an inner loop. Solving for r = 0 tells us that the loop runs from (2/3)pi to (4/3)pi.
The second curve has a radius function ranging from 2.5 to 0.5. Since the radius is never negative (or even zero), there will be no loop.
For a cardioid [tex]r =a + b\cos\theta[/tex] or [tex]r =a + b\sin\theta[/tex] , there will be a loop if a < b ; the curve will have a "dimple" if a = b ; for a > b , there is no loop.
I'm a little unclear on what you're asking here, but the radius function will be negative when [tex]\sin\theta[/tex] < -(1/2) , so there ought to be a loop for the interval from
(7/6)pi to (11/6)pi . There's a nice little animation for conchoids at http://mathworld.wolfram.com/ConchoidofNicomedes.html
Since you are working with cosecant, your conchoid will run "parallel" to the x-axis, but otherwise will behave like the one in the illustration I refer to.
  • · Replies 19 ·
  • · Replies 21 ·
