| Thread Closed |
The Photoelectric Effect Help |
Share Thread | Thread Tools |
| May17-08, 03:26 PM | #1 |
For an incoming light shining on a metal surface, I am given the wavelength, the cutoff voltage, the frequency (by using f = c/w). From here, Im having trouble finding the maximun Ek of the ejected electrons in electron volts (eV) and joules (J). 2. Relevant equations Ek max = eV E = hƒ = hc / λ Ek max = E (photon) - work 3. The attempt at a solution Im guessing that i can use the equation Ek max = eV by substituting in the cutoff voltage and the charge on an electron to get the Ek max in joules, but then how do I get it in electron volts? Is there a conversion factor, or another equation I use?? PLz help.. |
| May17-08, 03:54 PM | #2 |
Joules to eV...1.602 times 10^-19J= 1 ev
| May17-08, 04:03 PM | #3 |
| May18-08, 12:06 AM | #4 |
Recognitions:
The Photoelectric Effect HelpIf you use charge in Coulombs (for example [itex]e= 1.6\times 10^{-19}[/itex] C) then the energy is in Joules. If your charge is just the number of elementary charges (here 1), then multiplying by the cutoff voltage you get electronvolts. Two examples: If an electron moves through a 20 V potential difference, the change in potential energy is 20 electronvolts (could be positive or negative depending on the direction). If a helium nuclei (with a positive charge equal to 2e) moves through a 30 V potential difference, the change in potential energy is 60 electronvolts (again, could be positive or negative). (By the way, I don't understand what you mean in your last post when you say you found the energy in Joules, divided by the conversion factor and got volts again. If your kinetic energy in Joules was (for example) [itex]2\times 10^{-17} J[/itex], then converting to electron volts would be: [tex] 2\times 10^{-17} \mbox{ J} \frac{1 \mbox{ eV}}{1.6\times 10^{-19} \mbox{ J}} = 125 \mbox{ eV} [/itex] |
| May18-08, 02:08 PM | #5 |
i meant that if i have a cutoff voltage for a light (lets say its 2 V) i should multiply it by e to get the energy in joules (which would be in this case 3.2 x 10^-19 J). if i take that energy and divide it by e, then ill just end up at volts again...
cause E = eV |
| May18-08, 04:38 PM | #6 |
Recognitions:
(My example was if an electron goes through a potential difference of V=20 volts, its potential energy change is [itex]\Delta U=[/itex] 20 electronvolts.) |
| May18-08, 09:25 PM | #7 |
ohh ok, thx for your help.
| Thread Closed |
| Thread Tools | |
Similar Threads for: The Photoelectric Effect Help
| Photoelectric Effect. | Introductory Physics Homework | 1 | ||
| photoelectric effect | General Physics | 22 | ||
| Photoelectric Effect | Introductory Physics Homework | 8 | ||
| Photoelectric effect | Quantum Physics | 0 | ||
| photoelectric effect | Introductory Physics Homework | 5 | ||
