What are the angles for static equilibrium in a board supported by a rope?
  • Thread starter Thread starter Oomair
    Angle Minimum
The problem involves a uniform board supported at one end on the ground and held at an angle with respect to the vertical by a horizontal rope. The scenario includes considerations of static equilibrium, the coefficient of static friction, and the relationship between tension in the rope and the angle of the board.
  • Participants discuss the relationship between the angle of the board and the tension in the rope, questioning whether tension remains constant across different angles. There is also a focus on the normal force and its relation to the weight of the board in static equilibrium.
Some participants are exploring the implications of the normal force not being equal to the weight of the board in all scenarios, while others are questioning the constancy of tension in relation to changing angles. The discussion is ongoing with various interpretations being considered.
Participants are operating under the constraints of static equilibrium and the specific parameters of the board, including its length, mass, and the coefficient of static friction. There is an emphasis on understanding the mechanics involved without reaching a definitive conclusion.
Oomair
A uniform board of length 2.4 m and mass m = 5.1 kg has one end on the ground. With the aid of a horizontal force applied at the upper end by means of an attached horizontal rope, the board is held at an angle θ with respect to the vertical The coefficient of static friction between the end of the board and the ground is µs = 0.36.
What is the range of angles the board can make with the vertical and still be in static equilibrium?
How does the tension in the rope vary with the angle within the angle's possible range?
Ok they want the minimum angle, i found the max angle and the tension at the max angle, my question is that doesn't Tension stay the same since the length of the board is constant and normal force has to be present and equal to Mg? wouldn't the tension be the same at any angle?
I haven't fully read your question but the normal force is NOT always equal to Mg!
Consider a block lying on a slope. The normal force is directed perpendicular (not entirely vertical) to the slope and it's magnitude is only a part of the weight Mg.
i know that normal force is not always equal to mg, but in this situation the board is touching the ground at all time, and the normal force must be equal to the weight of the board so the system can stay in static equilibrium
Hi Oomair,
No, the tension will not be the same. For example, if the pivot for calculating torques is at the ground, then the torque from the weight force will change (since the moment arm is changing). The tension will have to adjust so as to keep the torques in balance.
  • · Replies 26 ·
