Finding Normal Mode Frequencies for Two Hanging Masses with Springs
This discussion focuses on deriving the Lagrangian for a system of two hanging masses, M_1 and M_2, connected by springs with constants k_1 and k_2. The user correctly identifies the kinetic energy expressions T_1 and T_2 as {1/2}M_1 \dot\delta_1^2 and {1/2}M_2 \dot\delta_2^2, respectively. The potential energy for M_2 is expressed as V_2 = -M_2 g (y_2+\delta_1+\delta_2) + {1/2}k_2(\delta_2-\delta_1)^2, while the potential energy for M_1 is debated, with the user considering the contribution from k_2. The main inquiry is how to find the normal mode frequencies, particularly when gravitational terms complicate the cancellation of exponentials in the equations of motion.
  • Understanding of Lagrangian mechanics and the formulation of the Lagrangian (L = T - V).
  • Familiarity with kinetic and potential energy expressions in mechanical systems.
  • Knowledge of normal mode analysis in coupled oscillators.
  • Basic grasp of differential equations and complex exponentials.
  • Study the derivation of the Lagrangian for coupled oscillators in classical mechanics.
  • Learn about normal mode frequencies and their calculation in multi-mass spring systems.
  • Explore the impact of gravitational forces on oscillatory motion in mechanical systems.
  • Investigate the method of undetermined coefficients for solving differential equations arising from Lagrangian dynamics.
Students and educators in physics, particularly those focusing on classical mechanics, as well as researchers interested in the dynamics of coupled oscillators and normal mode analysis.
Pacopag
A mass [tex]M_1[/tex] is suspended by a spring with constant [tex]k_1[/tex]. A second mass [tex]M_2[/tex] is suspended from the first by a spring with constant [tex]k_2[/tex]. The equilibrium height of the first is [tex]y_1[/tex] and the equilibrium height of the second is [tex]y_2[/tex].
I just want to write down the Lagrangian for now.
[tex]L=T-V[/tex] (i.e. Lagrangian is Kinetic energy minus Potential energy).
I'm using as generalized coordinates the displacements of the two masses from equilibrium [tex]\delta_1[/tex] and [tex]\delta_2[/tex]
I'm pretty sure that the kinetic energy parts are easy
[tex]T_1 = {1\over 2}M_1 \dot\delta_1^2[/tex] and [tex]T_2 = {1\over 2}M_2 \dot\delta_2^2[/tex]
Now for the potential energy for the second mass I think is
[tex]V_2 = -M_2 g (y_2+\delta_1+\delta_2) + {1\over 2}k_2(\delta_2-\delta_1)^2[/tex].
The first term is the gravitational part (taking the zero to be at the ceiling where the first spring is anchored) and the second term is the spring part.
But for the first mass, I'm tempted to write
[tex]V_1 = -M_1 g (y_1+\delta_1) + {1\over 2}k_1 \delta_1^2[/tex].
I think the spring part is wrong because [tex]M_1[/tex] is attached to spring 2, so there should be some contribution involving [tex]k_2[/tex]. This leads me to want to add another term like [tex]{1\over 2}k_2(\delta_2-\delta_1)^2[/tex], but I don't know if it should be positive or negative, and also I feel like I am 'double counting' the spring term in [tex]V_2[/tex]. For example, if spring 1 is streched and spring 2 is compressed, I expect [tex]V_1[/tex] to be increased by the compression of spring 2. I hope this is clear.
I've almost convinced myself that I should have
[tex]V1=-M_1 g(y_1+\delta_1)+{1\over 2}k_1\delta_1^2\pm{1\over 2}k_2(\delta_2-\delta_1)^2[/tex].
The sign is fuzzy to me, but thinking about the force (saying that down is negative), I think I should keep the minus. If this is correct, then I can get the equations of motion, which brings me to my real question: How do I find the normal mode frequencies? From similar examples, I've tried putting [tex]\delta_j = A_j e^{i\omega t}[/tex] (i.e. same frequency for both displacements (gen. coords)), into the equations of motion, then finding [tex]\omega[/tex] such that the solution exists. But, the gravitational terms don't allow us to cancel off the exponentials, which usually happens. I hope you can follow.
Sorry. It should just be
[tex]V_1=-M_1 g(y_1+\delta_1)+{1\over 2}k_1\delta_1^2[/tex].
But I still don't know how to find the normal mode frequencies.
  • · Replies 58 ·
