Register to reply
Physical significance
by salsabel
Tags: physical, significance
Share this thread:
salsabel
#1
May20-08, 06:45 PM
P: 17
Can some help me to solve this question
I have no idea where to start
a) What is the physical significance of the intercept of the graph with the frequency axis (x-axis)?
b) What is the physical significance of the intercept of the graph with the kinetic energy axis (y-axis)?
c) Use the graph to determine the value of Planck’s constant
d) In a similar experiment, the cathode of the photocell is replaced with a cathode that has a stronger force of attraction for its electrons. Describe how a graph of kinetic energy against frequency would be
i. Similar to the given graph
ii. Different from the given graph
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Hootenanny
#2
May21-08, 02:48 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,772
If you have no idea where to start, them I'm afraid we cannot help you. You must have some idea of how to start. Have you read your class notes/text on the subject matter?
jools111
#3
Jan7-10, 06:35 PM
P: 31
Quote Quote by Hootenanny View Post
I am working on the same question right now. First off, I am a little confused as to what they are asking in parts a) and b)... As far as part c) goes I tried the following method to determine h (Planck's constant) :
E=hf therefore,
h=E/f
So referring to the graph, at 3 eV (4.8 x 10^-19 J) the f is 10 x 10^14 Hz
h = 4.8 x 10^-19 J / 10 x 10^14 Hz
h = 4.8 x 10^-34 Js
This does not make sense as Planck's constant, as we know, is 6.63 x 10^-34 Js
Can anyone shed some light on these issues? Thanks!
ideasrule
#4
Jan7-10, 06:41 PM
HW Helper
ideasrule's Avatar
P: 2,322
E does not equal hf; it equals hf-W, where W is the work function of the metal.
I think parts a and b are pretty clear. The equation of the line in the graph is E=hf-W, so what do the intercepts represent?
jools111
#5
Jan7-10, 06:51 PM
P: 31
Quote Quote by ideasrule View Post
So the significance of the intercept of the x-axis is that is represents the threshold frequency, but there is no y intercept, so does that signify that there can be no Ek until the threshold freq. has been reached?
ideasrule
#6
Jan7-10, 07:42 PM
HW Helper
ideasrule's Avatar
P: 2,322
There IS a y-intercept. It's negative and doesn't represent an actual electron, but it does have physical significance.
Again, look at the equation of the line: E=hf-W
jools111
#7
Jan7-10, 07:56 PM
P: 31
I'm hitting a brick wall here... I'll start with what I know for sure:
h is constant, and f cannot be a negative
With f=0, the y-axis will be negative the value of the work function
So does the y-intercept represent the work function? (in the negative plane of course)
ideasrule
#8
Jan7-10, 09:38 PM
HW Helper
ideasrule's Avatar
P: 2,322
Yup, it's the negative of the work function.
jools111
#9
Jan11-10, 02:58 PM
P: 31
Perfect. So how would I prove Planck's constant without knowing the exact work function? Should I just use the value for W from the graph? Because it would be close but not exact...
richardnichol
#10
Mar1-10, 04:13 PM
P: 1
i would looooove to know the answer to c) & d). i figured out a) & b)!!!
Register to reply
Related Discussions
Physical significance behind [H, rho]=0 Quantum Physics 5
Physical Significance of Numbers General Physics 4
