Calculating Length Increase of Aluminium Bar Due to Temperature Change
The discussion revolves around calculating the length increase of an aluminium bar due to a temperature change, specifically from 20°C to 40°C. The bar has a diameter of 40mm and a length of 2.5m. Participants also explore the heat transferred into the bar using specific heat capacity values.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the formula for linear expansion and question the origin of the temperature difference in the equation. There is also inquiry about the reversibility of thermal expansion and the implications of decreasing temperature. Some participants express uncertainty about the calculations related to mass and heat transfer.
Several participants are actively engaging with the problem, attempting to clarify concepts and calculations. There is a mix of attempts to apply formulas and questions about the underlying principles. Guidance has been offered regarding the specific heat capacity and the need for mass in calculations, but no consensus has been reached on the final calculations.
Participants note the absence of weight information in the problem statement, leading to discussions about deriving mass from volume and density. The density of aluminium is provided, and there are considerations about unit consistency throughout the calculations.
speedy46
A 40mm diameter bar of aluminium is 2.5m long the bar is has its temperature raised from 20°c to 40°c. Determine the increase in length of the bar in mm. Take the Al = 24 × 10-6 °C-1
How much heat has been transferred into the bar if the SCH = 0.9kj/kg °C
Am stuck on where to start could anyone help please
Saying that you are stuck on where to start isn't an attempt at a solution. You much have some ideas as to where to start. Have you read your class notes or course text?
increase in length = linear expansion coefficient × length of material (t2 - t1)
I do not understand where the t2 - t1 come from.
Is it the temperture increase - the temperture of the bar before it is rasied.
Hi speedy46! :smile:
Yes, it's the temperature increase - final temperature minus initial temperature.
Increase in length is more if the original length is more,
and it's more if the temperature increase is more.
So it's proportional to both of them (in other words, to their product). :smile:
would this also work for decreassing temperture on a material?
Yes … the effect is reversible.
If a particular temperature increase makes it longer, then the same decrease will return it to its original length. :smile:
And cooling it further will make it even shorter than its normal length.
Some armies used to keep iron cannonballs inside brass "barrels". If the temperature fell below freezing point overnight, the iron and the brass would both decrease in size, but the brass would decrease faster, so the cannonballs would get closer to the top, and sometimes one of them would even be forced out of the brass barrel! :biggrin:
please could you tell me if this right or not
increase in length = 24 × 10-6 × 40 mm (40 - 20) 24 ×10-6 × 40 × 20 = 0.0192
Looks good! :smile:
thank you now i have to work out how much heat has been transferred into the bar if the SCH= 0.9KJ/ KG degrees Celsius.
What does the SHC stand for please
Thank you
To work out heat transfer
Q= (t1-t2)/(l÷Ka)
so 20 - 40 = 20
20 divide by 2.5m divide by ?
I do not know what the Ka stands for
speedy46 said:
Q= (t1-t2)/(l÷Ka)
so 20 - 40 = 20
Sorry, I've no idea what Ka is … where did you get it from? :confused:
All you need can be found in the units of the SCH in the question:
speedy46 said:
SCH = 0.9kj/kg °C
/kg °C means per kilogram, and per degree.
So you find the number of kJ by multiplying 0.9 by the weight and also by the change in temperature … and nothing else! :smile:
btw, wikipedia gives the SCH as 0.9 J /g K … can you see why that's the same?
so the change in temperture is 20 degress 20-40=20
but the question does not give the weight or can i work this out.
hmm … that's very true! :rolleyes:
they only give you the volume, and you would need to know the density also. :cry:
density of aluminum is 2.7g/cm³
volume of the bar is πr^2*h π * 20 2 * 2500 = 3141592.654
I changed meters into millmeters to keep them in the same units 1000*2.5= 2500mm
so now what do I need to do knowing the volume and density
mass = volume times density,
then SCH = 0.9kj per kilogram, and per degree. :smile:
2.7 3 times 33141592.654 = 61835968.21
is this correct
is this correct
Sorry, you've lost me. :confused:
Write it out in full … and remember you need the mass in kg.
(and don't work to 10 significant figures! :rolleyes: )
volume of the bar is pie times 20 squared times 2500 = 3141592
The density of aluminum is 2.7g/cm3
Mass = volume times mass
mass = 3141592 times 2.7g/cm3
mass = 61835955.34
6.1kg
is this correct am unsure
mass = 61835955.34
6.1kg
Use the same units that you'll need at the end:
volume of the bar in cm3 is π times 2 squared times 250 = 3142
mass = 3142cm3 times .0027kg/cm3 = … ? :smile:
3142cm3 times .0027kg/cm3 = 8.4834 kg/cm3
erm … you mean 8.4834 kg. :rolleyes:
So the heat transferred in kJ is … ? :smile:
(btw, it's joules with a litlle "j", but J or kJ with a big "J" … like watts and W or kW, or Newtons and N or kN :smile:)
so now i place that number into the equation
0.9 times 8.4834 times 20 = 152.70 KJ
:biggrin: Woohoo! :biggrin:
(but "kJ", not "KJ"! :smile: )
152.70 j
speedy46 said:
152.70 j
Nooo … 152.7 kJ ! :smile:
Thank you
