Discover How to Measure Liquid in a Spherical Bowl with a Hole using Radius R
  • Thread starter Thread starter bpuk
The problem involves measuring the volume of liquid in a spherical bowl with a radius R that has a small hole at the top. The task is to determine the height at which to mark the bowl to indicate a specific volume of liquid, p mm, while considering the volume of the hole as negligible.
  • Participants discuss modeling the volume using horizontal slices and integrating to find the volume of each slice. There are questions about the limits of integration and the relationship between the variables used in the equations.
Some participants have offered guidance on using integration to find the volume of the slices, while others are exploring the implications of different variables and limits. There is an ongoing dialogue about the correct setup of the integral and the meaning of the variables involved.
There are uncertainties regarding the definitions of variables and the limits of integration, as well as the interpretation of the spherical geometry involved in the problem.
bpuk
ok so i have a homework question that goes around the lines of a perfect sphere is used as a measureing bowl with radius R is given, this has a hole in the top in which it is filled with water (volume of this discounted as it is relatively small), we are asked to find at what height (relative to the centre) marks should be made to show that there is p (mm) of liquid in the bowl??
i am really stuck on this someone please.
i don't know how to edit but i know in order to do find the volume i will have to model a cone within th experiment obtian the limits and then derive a function but i am for the life of me unable to comprehend on how to start it
Welcome to PF!
Hi bpuk! Welcome to PF! :smile:
Divide the volume into horizontal slices each of thickness dz, find the volume of each slice (as a function of z), and then integrate. :smile:
so basically i will be working in terms of finding the integral (from the R to R-h) of the area of a cross section being pi*r^2??
or is it the int[sqrt(radius^2 - z^2)] between Radius and radius - height??
No, sqrt(radius^2- z^2) is just "r" itself for each "slice". Since the volume of each slice is
[itex]\pi r^2dz[/itex], you want [itex]\pi\int (radius^2- z^2)dz[/itex].
hmm,
but yeah that's what i thought but how do we then know the radius of each "slice" if we continued to work through the problem?
and were the Z limits ok?
using that [itex] \pi\int (radius^2- z^2)dz[/itex]
i found that intergrating it came out to be 1/2 ln (z+sqrt(r^2+x^2)r^2 + 1/2*x*sqrt(r^2+x^2)
and going on from this i found the integral of this is like [.5*ln(x+sqrt(r^2+x^2)r^2 + .5*x*sqrt(r^2+x^2)]
which seems a bit crazy.
Hi bpuk! :smile:
I don't understand where your sqrt came from … there's no sqrt in the formula.
And is your x the same as your z, or something different? :confused:
Just integrate π(r^2 - z^2). :smile:
tiny-tim said:
Hi bpuk! :smile:
umm the sqrt came from the spherical formula cos you have to sqrt the side you have as in x^2+y^2+z^2=R^2.
and yesh i understand to integrate the eqn but in terms of the next step what is that lil r in reference to is that the main radius i know or the one of the smaller cut.
as in if i know go to integrate it i get pi*r^2*z - (z^3)/3*pi
do i then go my known limits of R and R-H here
and then what happens to the small r??
(My r should have been R.)
Yes … calculate π[R^2*z - (z^3)/3] from -R to H. :smile:
12K
  • · Replies 51 ·
  • · Replies 29 ·
  • · Replies 40 ·
9K
