| Thread Closed |
potential difference on a charge between insulating plates |
Share Thread | Thread Tools |
| May23-08, 12:21 PM | #1 |
A small sphere with mass 1.50g hangs by a thread between two parallel vertical plates 5cm apart. THe plates are insulating ahnd have uniform surface charge densities + and - [tex]\sigma[/tex]. The charge on the shpere is q = 8.90 x 10^-6 C. What potential difference between the plates will cause the the thread to assume an angle of 30 degrees with the vertical? 2. Relevant equations Va->b = Ex E = [tex]\sigma[/tex]/[tex]\epsilon[/tex]0 Va->b = [tex]\sigma[/tex]d/[tex]\epsilon[/tex]0 3. The attempt at a solution I am actually a little stuck as to where to begin, I know the sphere orginally hangs on its string at x = .025m, and since the opposing plates are oppositely charged the positive sphere is attracted to the negative plate and raised a certain distance at an angle of 30 degrees. would I be right in assuming I could find the magnitude of the surface charge density utilizing the potential with formula kq/r, with r = .025m; then use that density in the equation with potential at r = .025cos30 (the point where the shpere is pulled by the negative plate)? so it would turn out like this: [tex]\sigma[/tex] = [tex]\epsilon[/tex]0V.025->0/.05 then use this value in the equation: Va->b = [tex]\sigma[/tex].025cos30/V.025->0 ? any help is greatly appreciated. |
| May23-08, 12:32 PM | #2 |
Mentor
Hint: Find the value of the electric field' between the plates. |
| May23-08, 12:35 PM | #3 |
about your hint, didn't I do that already? E = sigma/eplison0 |
| May23-08, 12:36 PM | #4 |
First of all, your use of LateX is really annoying, sorry :(
You don't have to type each letter in a seperate tex block, just type them all in one block. Also, fractions can be made using: \frac{a}{b} = [tex]\frac{a}{b}[/tex]. On to your question... I don't see you using any force in your attempt. Surely the only thing that can move the sphere will be a force? The force is a result of the positive plate charge attracting the negative sphere; this is what will cause the sphere to move. If you can figure out what force is needed to make the sphere hang at an angle of 30 degrees, and you can also express this force in terms of the two charges, then you can also find the potential difference that will cause the force you are looking for. |
| May23-08, 12:43 PM | #5 |
sorry about that, oh and the sphere is positive.
would this be correct as far as the force goes? F = qE = qsigma/eplison0 |
| May23-08, 12:47 PM | #6 |
Mentor
You must begin by identifying all the forces acting on the sphere. (I count three.) In any case, one of those three forces acting on the sphere is the electrical force. Use the conditions for equilibrium to solve for the E field, then calculate the potential difference. |
| May23-08, 12:49 PM | #7 |
Mentor
| May23-08, 01:00 PM | #8 |
nope, that's how the book worded it, the surface charge's value was not given, they just said that there was one on each plate. saw from your other answer that I got the force due to field, are you saying I can calculate the work done by the force to find the potential? |
| May23-08, 01:15 PM | #9 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: potential difference on a charge between insulating plates
| finding electric potential difference to stop a electron between 2 plates | Introductory Physics Homework | 2 | ||
| potential difference between plates | Introductory Physics Homework | 4 | ||
| potential difference between two plates | Introductory Physics Homework | 1 | ||
| Potential difference between plates in a B-Field? | Introductory Physics Homework | 8 | ||
| potential difference and static charge | Introductory Physics Homework | 0 | ||
