Definite intergration area under curve bounded with line
The problem involves finding the area under a curve defined by the equation y = x^3 - 8x^2 + 20x, bounded by the x-axis and a vertical line through a stationary point. The original poster expresses confusion regarding how to account for this line in the area calculation.
  • The original poster has identified the stationary points and attempted to integrate the curve but is uncertain about how to incorporate the vertical line into the area calculation. Some participants suggest visualizing the problem and considering additional geometric shapes to aid in the area determination.
Participants are engaging with the original poster's confusion, offering suggestions for visual aids and clarifying the integration process. There is a recognition of the need to consider the additional line in the area calculation, but no consensus has been reached on a specific method.
The original poster mentions a diagram included in the question paper, which may provide additional context for the problem setup. The presence of the vertical line complicates the area calculation, leading to questions about how to approach the integration limits.
thomas49th
A cruve has the equation [tex]y = x{3} - 8x^{2} + 20x[/tex]. The curve has stationary points A and B. There is a line through B parallel to y-axis and meets the x-axis at the point N. The region R is bounded by the curve , the x-axis and the line from A to N. Find the exact area under the curve
Well I found the x co-ords of A and B, which is [tex]\frac{10}{3}[/tex] or 2. I intergrated the curve and got
[tex]\frac{4x^{3}}{4} - \frac{8x^{3}}{3}+10x^{2}[/tex]
no +C as we'll be having limits i presume
But i don't know how to get the area of region R... as there is a stupid line in the way!
Can somebody show/help me to do it.
Hey
My first advice is to a picture of your problem. After that you notice that the exercise is to calculate the integral from x=A to x=B of f, i.e. integration of a polynomial. I expect you know how to do that.
i can intergrate a polynominal easily and in the question paper there is a picture of the question. But because of this AN line, it's thrown me. How would you go about doing it.
Thanks
Hi thomas! :smile:
If I've understood the question right, all you have to do is add a triangle (whose area is obvious), and you get the standard integral. :smile:
ahhh i see cheerz :)
  • · Replies 59 ·
