Differentiating U_{ave} with respect to beta using summation notation
  • Thread starter Thread starter raintrek
    Differentiation
The discussion focuses on finding the derivative of the average potential energy, \( U_{ave} \), with respect to the parameter \( \beta \) using summation notation. The correct formulation of \( U_{ave} \) is established as \( U_{ave} = \frac{\sum_k U_k e^{-U_k \beta}}{\sum_k e^{-U_k \beta}} \). A method involving the derivative of the partition function \( Z = \sum_k e^{-U_k \beta} \) is suggested, leading to the expression \( -\frac{\partial}{\partial \beta} \frac{\partial \ln Z}{\partial \beta} \) for the final answer. The discussion highlights common pitfalls, such as misapplying the quotient rule, which can lead to incorrect results.
  • Understanding of statistical mechanics concepts, particularly the partition function.
  • Familiarity with differentiation techniques in calculus, especially the quotient rule.
  • Knowledge of summation notation and its application in physics.
  • Basic understanding of exponential functions and their derivatives.
  • Study the derivation of the partition function in statistical mechanics.
  • Learn about the properties of logarithmic differentiation and its applications.
  • Explore advanced calculus techniques for handling derivatives of summations.
  • Investigate the implications of \( \beta \) in thermodynamic systems and its relation to temperature.
Students and professionals in physics, particularly those studying statistical mechanics, as well as mathematicians focusing on calculus and its applications in physical systems.
raintrek
Find [tex]\frac{dU_{ave}}{d\beta}[/tex]
where
[tex]U_{ave}=\sum_{k}\left(\frac{U_{k}exp(-U_{k}\beta)}{exp(-U_{k}\beta)}\right)[/tex]
My answer is supposed to be [tex]-(U_{ave}^{2})+(U_{ave})^{2}[/tex]
However I keep getting zero. I can only assume that the summation sign has something to do with the final form of the answer, but I have no idea how to deal with it. Can anyone offer a suggestion? Thanks
I suspect you've written the problem incorrectly here. As you've written it,
[tex]U_{ave}=\sum_{k}\left(\frac{U_{k}exp(-U_{k}\beta)}{exp(-U_{k}\beta)}\right) = \sum_k U_k[/tex]
What it should be is
[tex]U_{ave} = \frac{\sum_k U_k e^{-U_k \beta}}{\sum_k e^{-U_k \beta}}[/tex]
This is a standard integral in statistical mechanics, and there's a neat trick that always goes along with solving it. Supposing U_k is indepent of beta, write the denominator as
[tex]-\sum_k \frac{\partial}{\partial \beta} e^{-U_k \beta}[/tex]
Pull the derivative outside the sum, and you note that what you have looks like (1/y) dy/dx = d(ln y)/dx. Then, take the second derivative of that result:
[tex]-\frac{\partial}{\partial \beta} \frac{\partial \ln Z}{\partial \beta} = \mbox{answer}[/tex]
where [itex]Z = \sum_k \exp(-U_k \beta)[/itex].
Hmm, I've transcribed the problem straight from the question sheet. I too had that thought.
I'm not sure I follow you with your methodology though. If I try to solve the equation using the standard quotient rule, it gives me zero - is there a reason for that?
