Uses of type I superconductors
  • Context: Graduate
  • Thread starter Thread starter ijustlost
    Superconductors Type
The discussion revolves around the practical uses of type I superconductors, particularly in comparison to type II superconductors. Participants explore applications, advantages, and limitations of type I superconductors in various contexts, including SQUIDs and other superconducting devices.
  • One participant inquires about practical uses for type I superconductors where type II cannot be used, suggesting a need for clarity on their unique applications.
  • Another participant notes that type I superconductors are used in SQUIDs, implying a potential advantage in resolution.
  • A different viewpoint suggests that the distinction between type I and type II superconductors is often not significant in most applications, particularly since high-Tc superconductors are all type II.
  • It is mentioned that niobium and its alloys, which are type II superconductors, dominate real-life applications due to their higher critical temperatures and current-carrying capabilities.
  • Aluminium is highlighted as an important low-Tc superconductor for fundamental research, with its advantages stemming from the ability to create high-quality junctions due to aluminium-oxide insulation.
  • Participants discuss the typical use of aluminium SQUIDs as tunable Josephson junctions rather than as magnetometers, indicating a specific application context.
  • There is a clarification regarding the cooling requirements for aluminium, with a participant questioning the use of He-4 cryostats and another providing details on the limitations of such systems.
  • One participant explains that while He-4 cryostats can reach low temperatures, they may not be suitable for applications requiring temperatures close to the critical temperature of aluminium.
  • Discussion includes the affordability and functionality of He-3 cryostats, with insights into their operational characteristics and noise issues in laboratory settings.
Participants express differing views on the significance of type I superconductors in practical applications, with some arguing for their relevance in specific contexts like SQUIDs, while others emphasize the predominance of type II superconductors in most applications. The discussion remains unresolved regarding the unique advantages of type I superconductors.
Participants mention limitations related to the critical temperatures of superconductors and the performance of different cryostat systems, indicating that the discussion is influenced by specific operational conditions and material properties.
ijustlost
Does anyone know of any practical uses for a type I superconductor, where it isn't possible to use a type II (which typically have higher critical temperatures so need less cooling etc)?
There must be a reason that Type I SCs are used in SQUIDs (resolution?).
Whether or not a superconductor is type I or II is generally of little importance in most applications. All high-Tc superconductors are type II so if you want to work at high temperatures there is no choice.
There are only a few low-Tc superconductors that are actually used and most of them are type II. Niobium and its superconducting alloys are all type II and are used in almost all real-life applications of superconductivity (including MRI magnets) since the Tc is rather high and they can carry reasonably high currents.
Anyway; the most important low-Tc superconductor for fundamental research is aluminium but that has little to do with the fact that it is type I; the main advantage is instead that aluminium-oxide is a very good insulator and can be created by simply exposing aluminium to an oxygen atmosphere during fabrication. This means that high-quality junctions can be created which in turn means that we can fabricate multilayer structures such as Josephson junctions, SQUIDs, SETs etc using relatively straightforward methods (shadow evaporation). It is MUCH harder to fabricate good Nb structures (and even then aluminium-oxide is used as the insulator).
Aluminium also has a fairly high Tc (1.2-1.6K) meaning even a simply He-3 cryostat will often do.
Most low-Tc SQUIDs are fabricated from niobium and aluminium SQUIDs are rarely used as actual magnetometers; Al SQUIDs are usually just used as "tunable Josephson junctions" since we can control the critical current (and therefore Ej) using an external magnetic field (this is used in e.g. split Cooper-pair boxes etc).
I have no idea what a split Cooper-pair box is, but thanks for the clarification anyway.
Or even a He-4 cryostat! (or was that a typo?)
Unfortunately not. A pumped He-4 cryostat will get down to 1.3-1.4K but that is still too close to Tc for most applications (the IV curve of an Al Josephson junction will be extremely smeared out at 1.3K, and it might not be superconducting at all).
Fortunately pumped He-3 cryostats are quite cheap nowadays so most labs can afford them; they will get down to about 260-300 mK and have a hold time of about 24 hours when wired up correctly. There are even cryogen-free closed-cycle He-3 systems that use cryocoolers to liquefy the He-3; meaning you do not even need liquid He-4 to cool the system (unfortunately they are very noisy; we have one where I work and the sound drives me nuts whenever I have to spend any time in that lab).
