Understanding the Multiplicity of Poles in Complex Analysis
  • Context: Undergrad
  • Thread starter Thread starter Icosahedron
    multiplicity Pole
The discussion centers around the concept of the multiplicity of poles in complex analysis, exploring definitions, examples, and extensions beyond polynomials. It encompasses theoretical aspects and technical definitions related to poles and singularities in complex functions.
  • One participant asks for clarification on the meaning of the multiplicity of a pole in complex analysis.
  • Another participant provides an example, stating that for the function f(z)=1/(z-z0)^n, the pole at z=z0 has multiplicity n.
  • A further clarification is made that the order of the pole of f at z equals the multiplicity of the zero of 1/f at z.
  • There is a question about whether this concept can be extended beyond polynomials.
  • One participant explains that the concept makes sense for the quotient of two holomorphic power series, leading to a Laurent series with a finite number of negative power terms.
  • Another participant mentions that isolated non-holomorphic points are called singularities, with e^(1/z) being an example of a worse than pole point at z=0.
  • A participant proposes that the multiplicity corresponds to the power of the term with the largest negative power in the Laurent series of the function.
  • There is a question about whether an isolated or essential singularity can be considered a pole with infinite multiplicity.
  • One participant offers a more general definition of a pole, stating that a function f(z) has a pole at z=a of multiplicity n if the limit of (z-a)^n f(z) exists, while the limit of (z-a)^(n-1) f(z) does not.
  • A participant expresses gratitude for the clarity provided by the definition offered.
The discussion includes multiple viewpoints and questions regarding the definitions and implications of poles and their multiplicities. No consensus is reached on the extension of these concepts beyond polynomials or the nature of singularities.
Participants express uncertainty about the classification of singularities and the implications of multiplicity in various contexts, indicating a need for further exploration of these concepts.
Icosahedron
In complex analysis, what is understood by the multiplicity of a pole?
thank you
For [tex]f(z)=\frac{1}{(z-z_0)^n}[/tex], the pole at [tex]z=z_0[/tex] has multiplicity n
i.e. the order of the pole of f at z, equals the multiplicity of the zero of 1/f, at z.
May this be extended beyond polynomials?
thanks!
it makes sense for the quotient of two holomorphic power series, yielding what is called a laurent series, i.e., a series with at most a finite number of terms of negative powers.
on any open set, the fraction field of the holomorphic functions form what is called the field of meromorphic functions on that set. those have at worst poles as non holomorphic points.
e^(1/z) has a worse than pole point at z = 0. isolated non holomorphic points are called (isolated) singularities. the simplest actual singularities of functions defined by power series, possibly infinite in both directions, i.e. summed over all integer powers of z, are the poles.
I.e. the multiplicity is the power of the term with the largest negative power in the laurent series of the function?
Does this also mean that an isolated/(essential?) singularity is a pole with infinite multiplicity?
More generally, a function f(z) has a pole at z= a of multiplicity n if and only if
[itex]\lim_{z\rightarrow a} (z-a)^nf(z)[/itex] exists but [itex]\lim_{z\rightarrow a} (z-a)^{n-1}f(z)[/itex] does not.
That definition put everything in place, thanks!
  • · Replies 39 ·
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 30 ·
