Can someone Please help me understand E(X) expected values in statistics
  • Thread starter Thread starter laura_a
    Statistics
The problem involves calculating the expected value of the maximum of two dice rolls given the minimum value. Specifically, it seeks to determine E(Y|X=x) for values of x ranging from 1 to 6, where X represents the minimum and Y represents the maximum of the two dice.
  • Participants discuss the definitions of X and Y, questioning whether X represents the maximum and Y the minimum, and explore the implications of these definitions on the expected values.
  • Some participants express confusion regarding the calculation of E(Y|X=1) and the reasoning behind it, while others attempt to clarify the relationship between the minimum and maximum values of the dice.
The discussion is ongoing, with participants providing insights and clarifications about the definitions and calculations involved. There is a recognition of the need to understand conditional expectation better, and some guidance has been offered regarding the implications of specific values of X on Y.
Participants note a lack of enjoyment in statistics, which may affect their engagement with the problem. There is also a mention of potential misunderstandings regarding the terminology used in the problem statement.
laura_a
I have two dice, let X and Y denote (rspectively) min and maximum of the number of spots showing on the two die. Determine E(Y|X=x) for 1 <= x <=6.
Basically all I need to do is work out E(Y| x=1), E(Y|x=2) and so on until x=6. The reason I am stuck is that the teacher has told me that E(Y|X=1)=1 and I don't understand how.
I was thinking that E(Y|X=2) so that means (I think) that when X=2 that is the maximum, so then I thought Y could either be 1 or 2, so that means 2/36 ? But how come E(Y|X=1) is =1?
See the problem is, statistics is the only branch of mathematics I don't enjoy so I can't really get my head around the question and what it's asking
I don't understand what you mean by the "min and maximum of the number of spots showing on two die". A die has a fixed number of spots so how can there be a minimum and maximum?
Do you mean to say that X is the maximum and Y is the minimum? Because it does not make any sense that E(Y|X=1) = 1 otherwise.
Suppose that that's what you mean. Then X = 1 implies Max{Die1,Die2} = 1. Clearly this is only possible in the case where Die1 and Die2 are both equal to 1, hence E(Y|X=1) = 1, as it's the only value Y can have.
Think of it like this. You roll one die. It comes up, say, 4. Then you roll a 4-sided die. What's your expected value now? This is how conditional expectation works. So, E[Min | Max=4] = 1/4*(1+2+3+4) = 2.5.
Say you have two die [tex]D_1[/tex] and [tex]D_2[/tex]. If one of them comes up as 1 and the other comes up as [tex]n[/tex] then [tex]min{D_1,D_2}[/tex] is always going to be 1. This is because the minimum of 1 and any other number has to be 1 because you can't roll lower than 1!
