| Thread Closed |
Simple example of the collapse of the wavefunction? |
Share Thread | Thread Tools |
| May29-08, 06:35 PM | #1 |
I'm not sure the double-slit experiment is one such example, maybe I have not understood it yet.
This experiment shows the wave nature of light due to the wavefunctions of photons. But how does it show a particle of zero size that is not just a burst of waves? |
| May29-08, 06:48 PM | #2 |
First, do not be quick to assume photons have zero width, because otherwise the uncertainly principle would have [tex]\Delta x = 0[/tex], which is forbidden.
The collapse of the wavefunction can be imagined by detecting the photon as it passes through one slits. With the detector off, the photon is in a superposition of paths 1 and 2 and the experimenter observes an interference pattern. With the detector on, the photon travels either path 1 or path 2,and no interference pattern is observed. |
| May29-08, 07:18 PM | #3 |
So where do I find an undisputable example of the collapse of the wavefunction? |
| May29-08, 07:40 PM | #4 |
I'm quite sure the double-slit experiment with light is NOT a good example of the collapse of the wavefunction. At least it's not a simple example. The famous experiment where you observe the particle as it passes through the slits is actually a THOUGHT experiment proposed by Feynmann, and it uses electrons, not light. I don't think it's ever been done with electrons, and I don't think it really works with light because there is no way of detecting single photons as they pass through slits.
I'd really like to see what people suggest as a simple example of the "collapse of the wave function." |
| May29-08, 07:42 PM | #5 |
I agree with you that I'd like to see a good example of the collapse of the wavefunction. |
| May29-08, 07:47 PM | #6 |
Can't believe no one noticed this. |
| May29-08, 07:55 PM | #7 |
Do they collapse to something that has a size? |
| May29-08, 09:07 PM | #8 |
I would just like to correct my [tex]\Delta x = 0[/tex] assertion:
In order to measure the position of a particle, one needs a probe (say a photon, if we use Compton scattering) of sufficient momentum. As the position measurement becomes more ideal (to the limit where we know exactly the particle's position and [tex]\Delta x = 0[/tex]) one needs a photon of infinite momentum. So the ideal position measurement is not forbidden, but it is strictly theoretical, as an infinite photon momentum implies an infinite photon energy. For all experimental measurements, the wavefunction does not collapse to a perfect position eigenfunction and so the resulting wavefunction has nonzero width. A good discussion of this subject is given in Shankar, 2e, Section 4.2 "Collapse of the State Vector". |
| May29-08, 09:16 PM | #9 |
See "Heralded Generation of Ultrafast Single Photons in Pure Quantum States" by Mosley in PRL. |
| May29-08, 09:30 PM | #10 |
I can't comment on your reference except to note that it is a very modern one whereas the collapse of the wave function was something that bothered people in 1927. So I think if we are looking for a simple example of the phenomenon we should be going back to the source rather than arguing after the fact. |
| May30-08, 02:58 AM | #11 |
| May30-08, 07:33 AM | #12 |
I think so, yes.
From my memory of Feynman's books, he may have been trying to express the fact that most physicists postulate that the wavefunction collapses after measurement. If we assume that it is true, we can derive many of the experimental predictions such as the uncertainty relation. As for the actual clockwork that occurs when a wavefunction collapses, your guess is as good as anyone else's. I think that's what he was saying. |
| May30-08, 08:47 AM | #13 |
So it has nothing to do with the double slits or the interference pattern? You could shine a weak light on a piece of photographic film and watch the dots appear one at a time, and that would be the collapse of the wave function?
| May30-08, 09:13 AM | #14 |
Yes, when the photographic film "measures" the position of the photon it collapses the particle's wavefunction.
There is a nice example of the "dots appearing one at a time" in the book Principles of Quantum Physics by French and Taylor. I do not have the book with me, but the figure is 2-2 (or 12-2, maybe?) showing a photograph that is "built up" over time by using a weak light source (10^5 photons or so). |
| May30-08, 11:47 AM | #15 |
Pete |
| May30-08, 12:18 PM | #16 |
| May30-08, 01:12 PM | #17 |
What is the evidence to show that it works this way? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simple example of the collapse of the wavefunction?
| clarification on wavefunction collapse | Quantum Physics | 17 | ||
| Wavefunction collapse: is that really an axiom | Quantum Physics | 32 | ||
| Can spacetime collapse a wavefunction? | General Physics | 2 | ||
| Reversing wavefunction collapse | Quantum Physics | 4 | ||
| Decoherence & collapse of the wavefunction! | Quantum Physics | 5 | ||
