| Thread Closed |
Ratio Test for Series Proof |
Share Thread | Thread Tools |
| May31-08, 09:41 AM | #1 |
Show that if [tex] Lim|\frac{a_{n+1}}{a_{n}}| = L > 1, [/tex] then [tex]{a_{n}\rightarrow \infty[/tex] as [tex]n\rightarrow\infty [/tex] Also, from that, deduce that [tex]a_{n}[/tex] does not approach 0 as [tex]n \rightarrow \infty [/tex]. 2. Relevant equations The book suggests showing some number r>1 such that for some number N, [tex]|a_{n+1}|> r|a_{n}|[/tex] for all n >N. |
| May31-08, 11:21 AM | #2 |
Okay, and what have you done on this problem? Have you shown, perhaps by induction on n, that [itex]|a_{n+1}|> r|a_n|[/itex]? Once you've done that, you might consider the "comparison test".
| May31-08, 09:03 PM | #3 |
How would I start that proof by induction? How can I verify that [itex]
|a_{2}|> r|a_{1}| [/itex]. Also, for the second part, once I show that [tex]|a_{n}|[/tex] tends to [tex]\infty[/tex] isn't it basic logic that [tex]a_{n}[/tex] cannot approach 0? |
| Jun1-08, 07:57 AM | #4 |
| Jun1-08, 10:00 AM | #5 |
| Jun1-08, 10:16 AM | #6 |
Suppose not, If L<1, then what happens when [tex]{\lim }\limits_{n \to \infty } a_{n}[/tex]? |
| Jun1-08, 10:27 AM | #7 |
If L>1 then the sequence would be unbounded right? Because the next larger term is always of a greater magnitude than the previous. If L is less than 1, then the sequence is bounded, and the limit goes to 0?
| Jun1-08, 10:35 AM | #8 |
Now, since book suggested: show that [tex] |a_{n+1}|> r|a_{n}|[/tex] for all indices [tex]n\geq N[/tex], you can use the Binomial formula to show that the sequences is unbounded. Hope that's clear. |
| Jun1-08, 01:48 PM | #9 |
REALLY IRRELEVANT but....
i've always wondered this, but how do you guys get all those math symbols in there? like the absolute value symbol, or the greater than equal to sign? |
| Jun1-08, 01:52 PM | #10 |
| Jun16-08, 05:55 PM | #11 |
| Jun17-08, 07:47 AM | #12 |
Well, you can use Bernoulli's Inequality, which is [tex](1+b)^n \geq 1 +nb[/tex]
Suppose that [tex] L>1[/tex], then define [tex]b=\frac{L+1}{2}[/tex] since b<L. There exists a natural number N such that [tex]\frac{a_{n+1}}{a_{n}} \geq b[/tex] for all indices [tex]n \geq N[/tex] (just a reiteration of the problem) From here, use the Bernoulli's inequality to show that for some k and let r = [tex]b^k[/tex], then [tex]|a_{N+k}| \geq r|a_{N}|[/tex] which implies that the sequence [tex]a_{n}[/tex](the hint that your book gave) is unbounded. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ratio Test for Series Proof
| power series, ratio test. | Calculus & Beyond Homework | 1 | ||
| Is it ok to do this with the ratio test for series??/ | Calculus & Beyond Homework | 1 | ||
| [SOLVED] How simplifying this ratio test for series? | Calculus & Beyond Homework | 15 | ||
| Using root test and ratio test for divergence | Calculus & Beyond Homework | 2 | ||
| Infinite Series - Ratio Test | Calculus | 4 | ||
