What happens if I rotate a current-carrying wire?
  • Context: Graduate
  • Thread starter Thread starter el_greco
    Rotate Wire
The discussion revolves around the effects of rotating a current-carrying wire on the magnetic field it produces. Participants explore theoretical implications, mathematical formulations, and conceptual understanding related to the orientation of the wire and its influence on the magnetic field, with a focus on the Biot-Savart law and its applications.
  • One participant describes the magnetic field produced by a straight current-carrying wire along the z-axis and questions how this field changes when the wire is rotated at an angle theta.
  • The same participant proposes two ideas: the first suggests that only the component of the wire along the z-axis contributes to the magnetic field, leading to a modified expression B' = Bsin(theta); the second suggests analyzing the magnetic field in terms of its components, resulting in Br' = Bcos(theta) and Bz' = Bsin(theta).
  • Another participant agrees with the second idea, stating that the field will maintain its orientation relative to the wire regardless of the wire's angle.
  • A different participant mentions that using a vector direction notation can simplify the analysis without relying on a specific coordinate system.
  • One post diverges from the main topic, introducing a question about electromagnetic induction in transformers, specifically regarding magnetic flux linkage and its implications for turn ratio calculations.
  • A later post introduces a related problem involving a rotating wire with a cross-sectional area and asks for calculations of the magnetic field produced everywhere.
Participants generally agree on the conceptual understanding that the orientation of the wire affects the magnetic field, but there is no consensus on the correctness of the proposed mathematical formulations. The discussion remains unresolved regarding the implications of the rotating wire and the introduction of the transformer question adds complexity without clear agreement.
Some assumptions regarding the wire's rotation and its effects on the magnetic field are not fully explored. The discussion also includes a shift in focus to transformers, which may introduce additional variables not directly related to the initial question about the rotating wire.
This discussion may be useful for students and enthusiasts of electromagnetism, particularly those interested in the applications of the Biot-Savart law, magnetic fields, and electromagnetic induction in practical scenarios such as transformers.
el_greco
Let's assume that we have a straight current-carrying wire, along the z axis of the cartesian (or cylindrical) coordinates' system. Biot - Savart law tells as that the magnetic field at a distance r from the wire is [itex]dB=\frac{\mu_0}{4\pi}I\frac{d\boldmath{l}\times r}{r^3}[/itex], where dl is the wire element.
After we integrate over the whole wire, (assume it's infinite), we get the well known expression [itex]B=\frac{\mu_0 I}{2\pi r}[/itex].
My question is: What happens to the magnetic field, in case we "rotate" the current carrying wire, so it's no longer perpendicular to the xy (or [itex]r\varphi[/itex]) plane, but it has an angle theta ?
My first idea was that the only change is at the [itex]dl[/itex] element of the law, since it will no longer be along the z axis, but "analyzed" in two perpendicular vectors that will be added... vector-like. The new dlz will be the only element that will be giving a dBz field, whereas the new "dlx" (or "dlr") will not give a field, since the cross product dlr x r will be zero (the two vectors are along the same axis). So, the field B' in comparison with the initial field B will be B' = Bsin(theta). (Only dlz contributes to the magnetic field)
My second idea (which was chronologically first, though :P) was pretty simplistic: I rotated the whole well known image of the current wire and the "rings" of magnetic field lines (the contours), well given by the "right hand rule", so every tiny "part" of the field, which was only Br first, will be now analyzed in a Br' and a Bz' components. So, this means that Br' will be Bcos(theta) and Bz' = Bsin(theta). If theta = 0 (ie our wire is straight and perp again, as it was initially) we have Br' = B and Bz' = 0 (pretty convenient...)
Is any of these two ideas correct? If not, does anybody have a really good solution for this? :)
Your second idea is basically correct. If you angle the wire with respect to your coordinate system, the field from the wire will also be "angled." In other words, the field will have the same orientation with respect to the wire, no matter what direction this wire is pointing in.
If you write the vector direction as [tex]{\bf I\times{\hat r}}[/tex], you don't need a coordinate system.
Electromagnetic induction in transformer
Hello!I would like to ask about Electromagnetic induction in transformer.As we learn that an alternating voltage is connected to the primary coil,the alternating current in the primary coil produces a magnetic flux linkage with the secondary coil which constantly changes.[tex]\phi[/tex]=magnetic flux linkage in each coil of primary and secondary coil
and the way that this formula(turn ratio)work out.Considering the transformer is ideal,why "the magnetic flux linkage in primary coil is same to secondary coil-using to work out the turn ratio formula" this assumption is true?We study of the solenoid that produce the magnetic flux density is affected by the number of turns per unit length of solenoid and yet for transformer,the solenoid is just like primary coil.With constantly changes of magnetic flux,the magnetic flux induced in the secondary coil is [tex]\phi[/tex]=NBA,B=magnetic flux density from primary coil,there is a 'N' inside the formula,so why should be the magnetic flux linkage in primary coil same as secondary coil?
Sorry!I am the new member for this forum,I post it wrong place.
an interesting problem relationated with that, is consider a wire, like yours, but with cross section area and besides it's infinit and have current, it is rotating about it axis with an constant angular velocity and calcule the B everywhere...:P
  • Sticky
  • · Replies 0 ·
