Conservation of energy, determining the speed from the change in position
The problem involves a bullet embedded in a block of wood, where the goal is to determine the bullet's initial speed based on the conservation of energy principles and the mechanics of the collision. The scenario includes parameters such as the masses of the bullet and block, the angle formed by the string after the impact, and the length of the string.
  • Mixed
  • Participants discuss the application of conservation of energy and momentum, questioning the assumptions made about energy conservation in the context of an inelastic collision.
Some participants have provided guidance on using momentum to find the velocity immediately after the collision, while others express confusion about the necessity of momentum due to the final state of the bullet-block system being motionless. Multiple interpretations of the energy conservation principles are being explored.
There is a debate regarding the energy transformations during the collision, with some participants noting that not all energy is conserved due to losses in the collision process, such as heat and sound.
zakare
A bullet with a masse (m) is shot into a block of wood with a masse (M) at a velocity of (v). The bullet is lodged into the block of wood which is attached to a string of (l) length. After the impact where the velocity of the wood-bullet mass is equivalent to zero, the string forms an angle (a) with the vertical axis.
m = 0.02kg
M = 15kg
angle a = 20 degrees
l = 1 meter
v = ?m/s
E(mec initial) = E(mec final) = mgh + 1/2*mv²
E(mec final) = E(mec initial)
1/2*mv² = (m + M)gh
v = sqrt((2(M + m)gh)/m)
h = 2sin²(a/2)
and I get the answer: 42m/s
The correct answer is 825m/s.
I'd appreciate any help. Thanks
Welcome to PF!
1/2*mv² = (m + M)gh
Hi zakare! Welcome to PF! :smile:
This is not an elastic collision.
The bullet embeds in the block, and energy is lost.
You can only use conservation of momentum for the collision (but you can use conservation of energy after the collision).
Use momentum to find the velocity immediately after the collision, then use energy! :smile:
To reiterate what Tiny Tim just said, you need to see up two equations. One for conservation of mechanical energy after the collision and one for conservation of momentum during.
By doing so, you can solve for both the initial velocity of the bullet and final velocity.
Also, "1/2*mv² = (m + M)gh" should be [tex]\frac{1}{2}(m+M)v^{2}_{f}=(m+M)gh[/tex] since the bullet is lodged in the wood block so the mass is the total mass of the bullet and the wood block.
Also, how did you get h? You are given [tex]\theta[/tex] with the vertical, l=length of the string. Now find h (the height reached at the top of the swing) using a simple trig identity.
I don't see why I should use momentum because at the end of the sequence the bullet-block combination is motionless (vfinal = 0) and the angle is the angle max.
And to konthelion:
Why wouldn't it be what I wrote if the initial velocity of the bullet is what contains all the energy of the system (in kinetic form), and afterwards all the energy is in potential gravitational form...
Hi zakare! :smile:
You always have conservation of momentum in collisions.
… afterwards all the energy is in potential gravitational form...
No it isn't!
Some of the energy has gone into the bullet pushing into the block, also heat and sound.
Energy is not conserved.
