Kinetic Energy Change with Changing Velocity Directions
The discussion revolves around the change in kinetic energy of an object transitioning from a velocity of 10 m/s eastward to 30 m/s southward. Participants explore the implications of this change in a two-dimensional context, questioning how kinetic energy is calculated when direction changes occur.
  • Participants discuss whether the object must stop its eastward motion before moving southward and how to calculate the change in kinetic energy. Some suggest using the Pythagorean theorem for velocity changes, while others emphasize that kinetic energy is a scalar quantity and should be treated with ordinary addition.
The discussion is active, with participants offering different perspectives on how to approach the problem. Some guidance has been provided regarding the calculation of kinetic energy, but there is no explicit consensus on the method to be used.
Mass is not provided in the problem, which leads to varying interpretations of how it affects the calculations. Participants are navigating the implications of kinetic energy in a two-dimensional motion scenario.
forty
If an object goes from moving at 10 m/s eastward to moving at 30 m/s southward, how does its kinetic energy change?
If the object is to to change its velocity from east to south it would have stop all of its eastwards motion and then move in the southwards direction?
i have no idea if this is correct but i did the following
.5m(10)^2 + .5m(30)^2
and get 500m (mass is not given in the problem)
Any help would be greatly appreciated!
This object is not moving in a one-dimension but in two-dimension. So, you can't just add/subtract them. You can use the Pythagorean theorem to find the change in velocity.
You don't need the mass. Since you are asked to find the change in kinetic and not the numerical values for the initial and final kinetic energy[tex]\Delta K=\frac{1}{2}m(v_{f}-f{i})^2[/tex]
Hi forty! :smile:
No … kinetic energy is a number, not a vector.
So it doesn't obey vector addition … it obeys ordinary addition!
What's the KE before? What's the KE after? How do you subtract one from the other? :biggrin:
so are you saying its just
.5m(30)^2 - .5m(10)^2 = 400m (J)
Yup! :smile:
(of course, the result will be in J only if the mass is in kg)
Sometimes physics really is that easy! :biggrin:
  • · Replies 21 ·
