Thread Closed
ODE on the plane
Share Thread
Jun3-08, 11:21 AM   #1
ODE on the plane
Can someone tell me how to solve the ODE,
d2x/dt2 = -cosx d2y/dt2 = -cosy in the plane?
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Jun3-08, 02:34 PM   #2
You can use seperation of variables and then integrate twice (with an integration constant!)
Jun3-08, 03:53 PM   #3
thanks
Jun4-08, 07:38 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
ODE on the plane
Those two equations are completely independent- so it is not necessary to "separate variables". You are just solving two separate second order differential equations. And, in fact you just need to integrate each twice.
Jun4-08, 12:10 PM   #5
Recognitions:
Homework Helper Homework Help
Quote by HallsofIvy View Post
Hrm? They don't look independent to me. The derivatives are with respect to t, not x or y. Integrating the x equation would give, for instance,
[tex]\dot{x(t)} - \dot{x(t_0)} = \int_{t_0}^{t}d\tau~\cos y(\tau)[/tex]
which isn't so useful if you can't solve for what y(t) is.
Jun4-08, 05:29 PM   #6
Recognitions:
If d2x/dt2= cos(x) is a single equation in the dependent variable x as a function of t. There is absolutely no reason to introduce y. Since the independent variable "t" does not appear in the equation, I would use "quadrature":
Let v= dx/dt so that d2x/dt2= dv/dt= (dv/dx)(dx/dt)= v dv/dx. Now you have vdv/dx= cos(x) or vdv= cos(x)dx. Integrating, (1/2)v2= sin(x)+ C. dx/dt= v= [itex]\sqrt{2(sin(x)+ C)}[/itex] or
[tex]\frac{dx}{\sqrt{2(sin(x)+ C)}}= dt[/tex]
That left side is an "elliptical integral".
Of course, y will be exactly the same, though possibly with different constants of integration.
Jun4-08, 11:36 PM   #7
Recognitions:
Ah, I see, I didn't parse the problem the way it was intended to be read. I read it as
[tex]\frac{d^2x}{dt^2} = -\cos x \frac{d^2y}{dt^2} = -\cos y [/tex]
i.e.,
[tex]\frac{d^2x}{dt^2} = -\cos y[/tex]
and
[tex]\cos x \frac{d^2y}{dt^2} = \cos y [/tex]
This is why I always use some sort of punctuation in between separate equations written on the same line. =P
Jun5-08, 06:59 AM   #8
Recognitions:
And how do you know that was how it was "intended to be read"?
Jun5-08, 07:26 AM   #9
I was able to get to the elliptic integral. But I have no idea what it looks like. Further, if x and y are both the same elliptic integral then the orbits in the plane should be fairly simple. But what do they look like?
Thread Closed
Similar discussions for: ODE on the plane
Thread Forum Replies
Proton hits infinite charged plane, find charge of plane Introductory Physics Homework 1
Finding a plane given a line and plane ortogonal Calculus & Beyond Homework 2
Vectors in the Plane: Plane+Wind question.. Precalculus Mathematics Homework 2
Find plane, given a line & perpendicular plane Calculus & Beyond Homework 2
A plane intersecting another plane General Math 6
