Register to reply
Derivation of Escape Velocity Inconsistency
by Michael King
Tags: derivation, escape, inconsistency, velocity
Share this thread:
Michael King
#1
Jun8-08, 02:25 PM
P: 10
Hey, I'm a first year Astrophysics student, and in revising the Schwarzchild radius, I wanted to derive it and so I started by deriving the escape velocity from first principles, then rearrange to get the Schwarzchild Radius. Child's play, really.
However, depending from where you come from, either from energy or rotational motion, you end up being a factor of [tex]\sqrt{2}[/tex] out:
First Derivation, from Newtonian Mechanics
I am ignoring vector notation for speed
[tex]F = \frac{GMm}{r^{2}} = ma[/tex]
[tex]a = \frac{GM}{r^{2}}[/tex]
However,
[tex]a = \frac{v^{2}}{r}[/tex]
Therefore,
[tex]\frac{v^{2}}{r} = \frac{GM}{r^{2}}[/tex]
Rearranging for v gives
[tex]v = \sqrt{\frac{GM}{r}}[/tex]
Second Derivation, from Energy
We can assume that by units,
[tex]E = \frac{1}{2}mv^{2} = \frac{GMm}{r}[/tex]
[tex]E = \frac{1}{2}v^{2} = \frac{GM}{r}[/tex]
[tex]E = v^{2} = \frac{2GM}{r}[/tex]
[tex]v = \sqrt{\frac{2GM}{r}}[/tex]
Are my mathematics skills not up to scratch, or is it that for two equally valid derivations, we get two equally valid equations, that mean the same thing, but are not equal to one another?
Phys.Org News Partner Astronomy news on Phys.org
Thermonuclear X-ray bursts on neutron stars set speed record
How can we find tiny particles in exoplanet atmospheres?
Spitzer telescope witnesses asteroid smashup
Oberst Villa
#2
Jun8-08, 02:45 PM
P: 145
I suspect that in your first derivation, you are not calculating the escape velocity, but instead the velocity needed to keep the test particle in circular orbit of radius r. The 3rd equation, thats the bad one:
This is the centrifugal acceleration of a particle moving with speed v in a circular orbit of radius r - its not related to the escape velocity.
Further, I see a more fundamental problem with your approach. You are using Newtonian Mechanics, but what you aim at is the Schwarzschild radius, which is a concept based on the General Theory of Relativity. So you have to use the equations of General Relativity right from the start (Though I have no clue how to do this, sorry...)
Michael King
#3
Jun8-08, 04:00 PM
P: 10
ah so the first derivation was for orbital velocity, whereas the second was for escape velocity... I hate it when people don't label things correctly, or when I cannot read.
Janus
#4
Jun8-08, 04:09 PM
Emeritus
Sci Advisor
PF Gold
Janus's Avatar
P: 2,361
Quote Quote by Oberst Villa View Post
Actually, you can derive the Schwarzschild radius from Newtonian escape velocity by simply setting the escape velocity to c.
Astronuc
#5
Jun8-08, 04:10 PM
Admin
Astronuc's Avatar
P: 21,875
In the first equation, one had a balance of force (acceleration) between gravitational force/acceleration and centripetal force/acceleration.
In the energy equation, one simply equates the change in gravitational potential energy required to go from r to infinity with the change in kinetic energy at r and assuming zero kinetic energy at infinity, i.e. one coasts to a stop at infinity.
So escape velocity is the minimum velocity to escape without additional thrust after leaving from r.
Oberst Villa
#6
Jun8-08, 04:59 PM
P: 145
Quote Quote by Janus View Post
Oooopsie... of course you are right and I was wrong, checked it at some other sources. Though I think its really strange - I would have thought that, if there is one place in the universe where newtonian mechanics is not applicable anymore, then this would be near a black hole ! Strange ! Anyway, thanks a lot for the correction.
Kurdt
#7
Jun8-08, 05:17 PM
Emeritus
Sci Advisor
PF Gold
P: 4,980
There is another way to derive the escape velocity involving calculus and Newton's second law.
rock.freak667
#8
Jun8-08, 05:57 PM
HW Helper
P: 6,202
Quote Quote by Kurdt View Post
Really? How does one do it using that? Have only done it using kinetic energy and the gravitational potential
Kurdt
#9
Jun8-08, 06:28 PM
Emeritus
Sci Advisor
PF Gold
P: 4,980
Quote Quote by rock.freak667 View Post
Try it yourself
[tex]F = m\frac{dv}{dt} = -\frac{GMm}{r^2} [/tex]
rock.freak667
#10
Jun8-08, 09:07 PM
HW Helper
P: 6,202
Try it yourself
hm...cancel out one of the m's and then say that [itex]\frac{dv}{dt}=v \frac{dv}{dr}[/itex],then integrate both sides and I'll get the same beginning as if I start with ke=gravitational pe. That's the correct way to do it?
Kurdt
#11
Jun9-08, 01:47 AM
Emeritus
Sci Advisor
PF Gold
P: 4,980
Yeah pretty much.
Michael King
#12
Jun9-08, 09:28 AM
P: 10
still doesn't change the fact that one is a root 2 factor out compared to the other though..
Deriving the Schwarzchild radius isn't the problem, regardless of method. I am just curious as to which escape velocity to use.
I am assuming from Newtonian Mechanics, that the velocity there is actually orbital velocity (the velocity it takes to stay in orbit)
By Conservation of Energy, it is the velocity needed to escape a body of mass M, with a radius of r.
So the Newtonian is actually irrelevant, as it appears that because it does not contain that vital '2', and also from the equations used, it does not match up the logic.
Kurdt
#13
Jun9-08, 09:39 AM
Emeritus
Sci Advisor
PF Gold
P: 4,980
Using the circular motion equation you're deriving orbital velocity not escape velocity. That is why there is a factor of root 2 in there.
Michael King
#14
Jun9-08, 03:34 PM
P: 10
thanks, I know
Register to reply
Related Discussions
Escape velocity huh? Introductory Physics Homework 10
Escape nelocity derivation Introductory Physics Homework 1
Escape velocity Classical Physics 15
Escape velocity Special & General Relativity 5
