So essentially a resistor eats up/throws away energy?
  • Thread starter Thread starter vmars
    Energy Resistor
The discussion revolves around the role of resistors in electrical circuits, particularly focusing on their function in controlling current flow and the associated energy dissipation as heat. Participants explore alternative methods for changing current flow without energy loss, considering both theoretical and practical implications.
  • One participant suggests that resistors lower current flow at the expense of heat, questioning whether this means they "throw away" energy.
  • Another participant proposes using a voltage source of lower voltage as an alternative to resistors.
  • A different view is presented that while resistors do convert energy into heat, in some applications, such as toasters or heaters, this energy transformation is desired rather than wasted.
  • Some participants mention that resistors can reduce total energy consumption in certain contexts, indicating a need to consider the overall system.
  • Transistors are suggested as another method to control current flow, although they also dissipate power.
  • It is noted that resistors can provide a load to a power supply, allowing for regulated power output instead of presenting a high drain or short circuit.
Participants express differing views on whether resistors "throw away" energy or if this energy transformation can be beneficial in certain contexts. There is no consensus on the best method for changing current flow without energy loss, as multiple alternatives are discussed.
The discussion includes assumptions about the definitions of energy loss and efficiency in electrical systems, which may vary based on context and application.
vmars
I understand that a resistor can lower current flow at the expense of heat.
Isn't there a better way to change current flow without throwing away energy?
Thanks!
...Vern
Use a voltage source of lower voltage?
Thanks!
...Vern
Yep, resistors turn energy into heat.
Sometimes the desired result is heat, say a toaster or room heater, so saying that energy is thrown away is incorrect.
In other cases a resistor can reduce the total energy consumed, so you have to look at the big picture.
In some cases alternate methods are used, for example switching power supplies.
You can also use transistors to affect current flow. You'll still have power dissipated, though.
It is also possible that a resistor (or several of them) will supply a load to a power supply such that that power supply can supply a regulated drain instead of appearing like a high drain or a dead short.
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 21 ·
