Aparent contradiction - pressure and velocity
The discussion centers around the apparent contradiction between the behavior of pressure and velocity in fluid dynamics, particularly in the context of Bernoulli's equation. Participants explore how changes in the x component of velocity might affect pressure, which is typically associated with the y component of velocity, and the implications of these relationships in fluid systems.
  • One participant asserts that an object's velocity in the x direction does not affect its velocity in the y direction, suggesting that the average y velocities of an ensemble of particles should remain unchanged with variations in x velocity, leading to no change in pressure.
  • Another participant explains that pressure is direction-less and relates to the average kinetic energy of particles or their collision frequency against surfaces, indicating that pressure can be constant throughout a fluid.
  • It is noted that Bernoulli's equation indicates that an increase in x direction velocity results in a drop in pressure, which some participants find contradictory to the idea that pressure is derived from y direction velocities.
  • A later reply elaborates that Bernoulli's principle assumes a closed system and ignores factors like friction and turbulence, explaining that changes in flow speed are related to pressure differentials in varying cross-sectional areas of a pipe.
  • Another participant mentions that particles collide and exchange energy in all directions, which may contribute to the overall dynamics discussed.
Participants express differing views on the relationship between pressure and velocity, particularly in the context of Bernoulli's equation. There is no consensus on how these concepts interact, and the discussion remains unresolved.
Participants highlight limitations in their understanding, such as the assumptions underlying Bernoulli's equation and the effects of external factors like friction and turbulence, which are not fully addressed in the discussion.
Fanaticus
So, I have in my mind an apparent contradiction that hopefully can be cleared up.
From early lessons we learn that an objects velocity in an x direction has no effect on its velocity in the y direction. So, the y component of a particles velocity is not effected when we change its x component of velocity. If we have a whole ensemble of particles, it should reason that the sum of their y components of velocity would also be unaffected by a change in their net x velocity. Now the average y velocities of an ensemble of particles determine what pressure is measured, so the pressure should not change.
But Bernoulli's equation says just the opposite... It says that if you increase the velocity in the x direction, the pressure drops. But the pressure comes from the particle's velocities in the y direction!
I think you can see my confusion at this apparent contradiction. Help me understand what is really going on!
Thx a lot
i'm not an expert on fluid dynamics, but here are a couple starting points:
1) pressure is direction-less. it is not a vector quantity. pressure is a measure of the average kinetic energy particles/molecules in a fluid, or, equivalently, the average collision frequency of particles/molecules against a surface (all for a given temperature).
consider a cubic box containing a gas. the gas has a constant pressure throughout the box, and you would quantify this pressure by measuring the number of collisions of gas molecules with the box surfaces. the top/bottom surfaces would see the same number of collisions as the side surfaces per unit area for a given pressure. the same concept can apply to fluids as well.
2) bernoulli equation relates a dynamic pressure from a flow to the static (stagnation?) pressure at a point generated by the stoppage of the fluid flow. this does not speak towards the relationship in a fluid of pressure and velocity.
Bernoulli's says if velocity in x direction increases, pressure in x direction increases (dynamic pressure) and pressure in y direction decreases (static pressure).
Fanaticus said:
That an objects velocity in an x direction has no effect on its velocity in the y direction. But Bernoulli's equation says just the opposite... It says that if you increase the velocity in the x direction, the pressure drops. But the pressure comes from the particle's velocities in the y direction!
For the first statement, if a force is applied to the object perpendicular to it's direction (a centripetal force), then no work is done, the kinetic energy remains the same, but the objects direction changes, and the components of velocity in the x, y, and z axis will change.
Bernoulli principle in it's simplest form ignores things like friction, viscosity or turbulence, and assumes a closed system, such as a pipe with varying diameters, which peforms no work on the fluid (or gas) (no friction, vicocity, or turbulent effects). Since the flow of mass across any cross section of the pipe is constant (else fluid or gas would be accumulating), then the speed of the flow is relative to the inverse of the cross sectional area. Since no work is done by the pipe, the only remaining cause for the changes in speed are pressure differentials, higher in the larger diameter sections of the pipe, lower in the narrower sections of the pipe, which result in the changes in net velocity in the direction of the flow. The average velocity and the total kinetic energy of the molecules in the fluid remains constant, but the net direction of these velocities will vary with the speed of the flow, and the component of kinetic energy calculated from the component of net velocity in the direction of flow will vary.
When the rate of flow increases in the Bernoulli pipe, the component of velocity in the direction of flow increases, and since the kinetic energy is constant, the component of velocity perpendicular to the direction of flow must decrease. What happens is that the nearly random collisions of the molecules become less random and more directional in during transitions to narrower sections of the pipe, resulting in a net component of acceleration during the transition to narrower sections and vice versa.
The particles collide with one another, exchanging energy in all directions.
  • · Replies 17 ·
  • · Replies 16 ·
