How Much Work to Stand Up a Telephone Pole?
  • Thread starter Thread starter armis
The problem involves calculating the work required to reposition an 8m, 200kg telephone pole from a horizontal to a vertical position. The discussion centers around concepts of work, torque, and the center of mass in physics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the concept of work in relation to lifting the pole, considering the center of mass and uniform mass distribution. Some suggest using integration to calculate work done, while others question the necessity of torque in the solution.
The discussion is active with various approaches being considered, including gravitational potential energy and torque. Participants are questioning assumptions about mass distribution and the implications for calculating work. No consensus has been reached, but several lines of reasoning are being explored.
Participants are discussing the implications of uniform mass distribution and the role of torque in the calculations. There is also mention of potential resources for understanding torque in classical mechanics.
armis
An 8m and 200kg telephone post is laying on the ground. What work one needs to do to reposition the post vertically?
:cry:
Umm, a telephone-post maintenance worker's job?
Are you asking about the amount of work to be done?
Oh sorry, I meant work :rolleyes:
Okay any thoughts about how you want to go about solving this problem? To simplify, assume that the post's mass is uniformly distributed. Where is its centre of mass?
If the mass is uniformly distributed then the center of the mass is in the center. Thus I need to lift the center by half of the length of the pole [tex]A = mgl/2 = 8 kJ[/tex]
thanks!
Now what about a numerical way to solve this? I was wondering about integrating somehow using the moment of force or something of the kind
What do you mean numerical method? You can find the centre of mass if required by integration, but other than that I don't see what else you should do.
Well if there would be a force acting on one end of the pole then I thought I could write and integral of some sorts and find out what work is done by the force to place the pole vertically
You can integrate [tex]- \tau d\theta[/tex], where [tex]\tau[/tex] is the torque on the rod due to its weight.
Thanks dx
Any book which explains torgue in detail? I imagine all on classical mechanics must have an explanation, just tell me
Why even bother with torque?
If you lift this log the 4 requisite meters and put in a magical frictionless bearing in the center, every orientation of the log has equal potential energy. So isn't the solution the gravitational potential of the center of mass at 4 meters?
Any solution involving torque would include the inertia of the pole about some hinge, which, although not unnecessarily complicated, is far more complicated than the gravitational potential formula.
Yep, we actually already did that. Read the previous posts
I wanted to involve torgue that's why I asked how to do it
thanks
armis said:
Thanks dx
Torque is basically the rotational equivalent of force. For example, you know that the work done by a force [tex]F[/tex] in moving an object a distance [tex]\Delta x[/tex] is
[tex]F\Delta{x}[/tex].
Now consider some particle on the plane with a force [tex](F_x, F_y)[/tex] on it. It you now rotate the particle about the origin by and angle [tex]\Delta \theta[/tex], the work done on it can be shown to be
[tex](xF_{y} - yF_{x})\Delta \theta[/tex].
So this strange combination [tex]xF_{y} - yF_{x}[/tex] is the torque, which is also the vector cross product of (x,y) and
[tex](F_x, F_y)[/tex]. This can also be written [tex]|r||F|sin\theta[/tex] where [tex]\theta[/tex] is the angle between
r and F.
In the case of your problem, the torque is [tex]- \frac{l}{2} mg cos\theta[/tex] where [tex]\theta[/tex] is the angle between the ground and the rod. If you integrate minus this from 0 to pi/2, you get the answer.
How can it shown to be [tex](xF_{y} - yF_{x})\Delta \theta[/tex] ?
why is it l/2 if the force is acting at the end of the pole?Is it because of the mass distribution?If it wouldn't be symmetric, then what?
thanks
Displace the particle by a small angle [tex]\Delta \theta[/tex], and the find the small displacements in the x and y coordinates in terms of this. If these are [tex]\Delta x[/tex] and [tex]\Delta y[/tex], then the work will be [tex]F_{x} \Delta{x} + F_{y} \Delta{y}[/tex].
thanks
No, the force acts effectively at the center of mass, which is the middle of the rod if it is uniform.
11K
  • · Replies 26 ·
9K
