| Thread Closed |
Should Toluene be clear or cloudy white? |
Share Thread | Thread Tools |
| Jun16-08, 10:06 PM | #1 |
I have very little background in chemistry.
A clear sample of toluene was poured into a non sealed bottle and after several hours it turned cloudy white. Is this normal? Why does this happen? It is still a clean solution of toluene right? |
| Jun17-08, 02:49 AM | #2 |
Admin
It shouldn't, there is some contamination. Was the bottle dry?
Borek -- http://www.chembuddy.com http://www.ph-meter.info |
| Jun17-08, 09:02 AM | #3 |
Or the bottle was not dry (or contained something that mixed with toluene) or the liquid has absorbed humidity from air.
| Jun17-08, 04:23 PM | #4 |
Hey,
The bottle was rinsed out with distilled water but not thoroughly dried. It sits in a near dust-free environment where temperature and humidity are controlled. The bottle had no previous chemical substance in it. Not for >3 years that I know off. |
| Jun18-08, 04:56 PM | #5 |
| Jun18-08, 05:00 PM | #6 |
really?? distilled water can be a contaminant?
| Jun18-08, 07:41 PM | #7 |
Yes, water can be a contaminant. Given that toluene's solubility in water is quite minimal, even a tiny bit of water can serve as a contaminant. Many organic solvents - including toluene - are typically sold as "dry" solvents (water-free or nearly so), since even a small amount can screw up someone's work.
| Jun18-08, 09:19 PM | #8 |
| Jun20-08, 11:11 AM | #9 |
Recognitions:
I'm not quite certain if water and toluene would mix to form a suspension you might want to observe a mixture without stirring it ; should find two immiscible phases. From my experience a small amount of water in certain organic substances forms a cloudy suspension with stirring ; at times at 2% however it should be higher for toluene. Surfactants can cause reverse miscelle formation with water and toluene also.
| Jun20-08, 04:48 PM | #10 |
I think I found the cause of the problem (along with water). The toluene was sandwiched between two transparent pieces of plastic. Apparently you can't place these chemicals on plastic due to some effect? The plastic turned all opaque and "cloudy white".
| Jun20-08, 05:00 PM | #11 |
Admin
Toluene is a pretty good solvent, it will penetrate many plastics and it will dissolve them to some extent.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Should Toluene be clear or cloudy white?
| how to make clear ice.clear ice | General Physics | 17 | ||
| cyclohexene and toluene + sulfuric acid | Chemistry | 1 | ||
| Toluene + bromine | Chemistry | 1 | ||
| Why do you get sunburnt on a cloudy day? | General Physics | 3 | ||
| Thoughts on a cloudy, rainy day | General Discussion | 5 | ||
