Calculating Power and Force in a Sprinter's Run
  • Thread starter Thread starter habibclan
    Power Work
The problem involves a 50 kg sprinter who accelerates from rest to cover a distance of 50 m in 7.0 seconds. The questions focus on calculating the horizontal force acting on the sprinter and determining the power output at specific time intervals.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate acceleration and force using kinematic equations and Newton's second law. They express confusion regarding the difference between average power and instantaneous power when calculating power output.
Participants are exploring the distinction between average and instantaneous power, with some clarifying that the problem likely requires instantaneous power. Guidance has been offered regarding the appropriate use of equations for different types of power calculations.
There is an emphasis on understanding the definitions of average versus instantaneous power, which may influence the approach to solving the problem. The original poster's calculations are based on the assumption of average power, leading to confusion when comparing results.
habibclan
A 50 kg sprinter, starting from rest, runs 50 m in 7.0 s at constant acceleration.
a. What is the magnitude of the horizontal force acting on the sprinter?
b. What is the sprinter's power output at 2.0 s, 4.0 s and 6.0 s?
xf= xo + vt+ 0.5*a*t^2
F= ma
vf= vi + at
P= (delta Work)/(Delta t)
P= f*d*cos angle
Using the distance, initial velocity, and time I solve for acceleration
50 = 0 + 0+ 0.5*a*(7^2)
a= 2.04 m/s^2
Therefore, F=ma=50 (2.04)=102 N
This, I got right. But when I calculate the power, I'm not getting the right answer when i use the first equation.
I calculate the velocity at t= 2s, and I get
vf = vi + at
vf= 2.04 ( 2)
vf= 4.08 m/s
Therefore work=delta kinetic energy= 0.5 m (vf^2 - vi^2)
K= 0.5 ( 50) ( 4.08^2)
K= 416.16 J
Therefore delta work=delta kinetic energy=416.16 J
Therefore Power= 416.16/ 2 s = 208.08 W.
Apparently the answer is just 416.16 J. When I use the second equation of P= F*v=102*4.08=416 J, I get the correct answer. Why are these two equations giving me different answers?
Taking the difference in the kinetic energies at t=0 and t=2 and dividing by 2 sec doesn't work for the same reason that taking the difference in the positions at t=0 and t=2 and dividing by 2 sec doesn't give you the velocity at t=0. They want an 'instantaneous power' not an 'average power'.
I didn't know that there was a difference between the two. So whenever I have a velocity I should use the second one?
There's definitely a difference between average and instantaneous. If they don't ask for average then they probably mean instantaneous.
Thanks a lot! I understand it now =).
  • · Replies 17 ·
