Energy required for particle accelerators
  • Context: Graduate
  • Thread starter Thread starter DSR
    Energy Particle
The discussion centers on the energy requirements for particle accelerators, particularly in relation to accelerating electrons and protons. Participants explore the implications of particle mass, energy levels, synchrotron radiation, and the design of accelerators, including the challenges and limitations faced in achieving high-energy acceleration.
  • One participant notes that while MeV and TeV energies seem small in Joules, the power requirements for accelerators like Fermilab are substantial due to the need to accelerate many particles simultaneously.
  • Another participant clarifies that Fermilab accelerates protons, which are significantly heavier than electrons, impacting the energy dynamics involved.
  • Concerns are raised about the limitations of accelerating small numbers of particles, as this would reduce luminosity and collision probabilities.
  • Participants discuss the concept of gradients in acceleration and the implications of accelerating particles slowly versus rapidly.
  • Questions are posed regarding the impact of synchrotron radiation on energy limits and whether there is a threshold where energy loss from radiation exceeds the energy input for acceleration.
  • Some participants suggest that larger accelerator radii reduce synchrotron radiation losses, while smaller particle masses increase these losses.
  • There is a discussion about the feasibility of designing accelerators that minimize synchrotron radiation by employing principles similar to atomic electron behavior.
  • One participant mentions the potential for accelerators to produce high-energy X-rays and inquires about the differences compared to X-rays produced by Bremsstrahlung.
Participants express differing views on the implications of particle mass and the efficiency of acceleration methods. There is no consensus on the best approach to minimize energy loss due to synchrotron radiation or the feasibility of alternative accelerator designs.
Participants reference various technical concepts such as duty cycles, luminosity, and the relationship between magnetic fields and particle momentum. Limitations in current accelerator technology, such as the strength of magnetic fields and the design of accelerating structures, are acknowledged but remain unresolved.
DSR
This one may sound a little naive, but I hope it is not thought inappropriate for this forum. The amount of energy required in an accelerator to speed an electron up to a sizable fraction of the speed of light is in the MeV range and bigger, more modern accelerators may even go up to the TeV range. One MeV, though, is only 1.602 x 10^-13 Joules, so 1 TeV = 1.602 x 10^-7 J. These seem like pretty small energies. Fermilab is about 4 miles around and uses about 50 MegaWatts a month! Why does it take such large, powerful machines to accelerate such light particles? :confused:
Thanks.
Fermilab doesn't accelerate electrons. That's why. A proton is many, many times heavier than an electron.
Furthermore, one can't just accelerate one electron using an arbitrarily large gradient. A particle accelerator accelerates a LOT of particles, and it has to do it in stages because we have no accelerating structure that can withstand arbitrarily high accelerating gradient without suffering catastrophic breakdown (that's why the ILC is proposed to be about 20 km long!). So one has to talk about "duty cycle". This is in addition to being able to efficiently transfer the power from the RF source right to the accelerating structures themselves.
BTW, for most practical purposes, an electron reaching MeV energy is already considered to be traveling at c. All our particle tracking code that does beam dynamics assume that.
Zz.
A proton is about 1000 times the mass of an electron, but the energy involved, even TeV, is still small, one ten millionth of a joule. So is the great power required because so many particles have to be accelerated together? So why can't you just accelerate a small number of particles to reduce the energy requirements?
I can see why you would want a very long round track. The larger it is, the lower the centripetal force has to be to pull the particles in a circle, so the magnets wouldn't need to be as powerful.
I'm not sure what you mean by gradients. Are you talking about the change in acceleration of the particles? Why can't they be accelerated slowly at a constant acceleration?
Then you lose luminosity, meaning you won't get that high of a probability of collision. That was the problem with Run 1 of the Tevatron.
Then you'd need an accelerator that is even LONGER and MORE EXPENSIVE. If you're willing to fork the money out for it (the ILC is now estimated to be around $10 billion for 20 km), I'll build it.
Zz.
Another thing, does cyclotron or synchrotron (or whatever it is) radiation limit the energy that a particle can be accelerated to? Or does it just require increasing levels of energy to keep accelerating the particle? Is there a point at which the particle loses more energy from radiation than what can be put into accelerate it?
Just to add a little point I think to make it clear. One eV is the energy an electron acquires when accelerated by one V on one m. Therefore, to accelerate one electron to 1 TeV, you merely need one cavity one meter long with 1000 billion of V. :-p
I would say mostly yes, but Zz knows better than me. Here we have two LINACs with recirculating arcs
To know how much a particle will radiate, the relevant quantity is to compare its mass to its energy (and the radius over which you have it turn).
The bigger the radius, the less syncrotron radiation loss. And the smaller the mass, the bigger loss of syncrotron rad.
The advantages of a circular accelerator is that you can use each unit several times, in a linear accelerator you can only use a unit once. The disadvantages od circular acc is sync rad loss.
This has absolutely nothing to do with the question.
It does when the OP is using the example of electrons and asking why it takes so much power at Fermilab. Furthermore, if you look at accelerators that accelerate protons versus one that accelerate electrons, the latter is a lot more "simpler" to get to the same energy.
Zz.
The limitation are the magnetic field, you see:
p = 0.3*R*B
the radius R is constant in LHC for instance, so when the momentum (energy) of the particle is increased, you need a higher B-field to keep it in same radius.
And the limitations are today the field from the magnets, we can't make arbitrary strong magnets.
And the loss of syncrotron radiation depends on energy of beam and radius, and mass of particle. So one wants to optimize these conditions. At LHC, this is done by choosing the heavy proton, and not the electron. The procentual loss of syncrotron radiation energy per revolution is always less than 100%.
Hi:
I have heard that particle accelerators can produce x-rays, how are these X rays different form for example an x-rays produced in Bremsstrahlung, I know that X rays produced in accelerators are more energetic, but what else besides that..?
Thanks for your answer
Would it be possible to design an accelerator that minimizes or eliminates the synchrotron radiation by using the same principle that an atom uses to maintain an electron in a stable energy shell around its nucleus without it spiraling in towards the nucleus by creating a stable standing wave pattern of the electron mass wave. Would this work in principle, even if it may be difficult to implement? Could one develop an electron (or proton) maser for this purpose which, instead of operating on photons and electromagnetic waves, uses electrons (or protons) and mass waves?
  • · Replies 0 ·
