Solve Urgently Needed: Related Rates Swimming Pool Problem
The problem involves calculating the rate at which the water level is rising in a swimming pool with an inclined bottom, given specific dimensions and a rate of water being pumped in. The pool's dimensions are 24 m long, 8 m wide, with varying depths of 1 m and 3 m.
  • Mixed
  • Participants discuss the relationship between the volume of water and the height of water in the pool, questioning the formula for the exposed surface area and its dependence on time.
  • Some participants attempt to derive the volume formula using the area of the triangular cross-section and the width of the pool.
  • There are inquiries about the correctness of the calculated rate of change of height, with some expressing confusion over the application of certain formulas.
  • Several participants reflect on their understanding of the problem and the implications of their calculations, particularly regarding the teacher's feedback on their answers.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided alternative approaches to the calculations, while others express uncertainty about their methods and results. There is no explicit consensus on the correct answer, but several participants are engaging with the material and attempting to clarify their understanding.
Participants note discrepancies in their calculations and the feedback received from their instructor, which has led to confusion regarding the validity of their answers. The discussion reflects a mix of confidence and uncertainty about the mathematical relationships involved in the problem.
rum2563
A swimming pool is 24 m long by 8 m wide, 1 m deep at the shallow end and 3 m deep at the deep end, the bottom being an inclined plane. If water is pumped into the empty pool at a rate of 2m^3/min, then how fast is the water level rising at the moment when the water is 1 m deep at the end of the pool.
dh/dt = 1/As x dV/dt
As: area of exposed surface
Basically I used ratios to get the length of the pool when the height is 1 m deep.
1/3 = x/24
So x = 8 m.
Then As = 8*8 = 64 m^2
dh/dt = 2/64
= 1/32 m/min
I am not sure what I am doing wrong. I have my diagram attached. Please tell me what I am doing wrong. Also, if you have the answer please tell me because I need this urgently. I can use the answer and then work it back to get everything right.
Thanks.
The surface area 'As' is a function of time as well, it's not just a constant you can factor out.
So would that I mean I have to use some other formula rather than the As one. Because my teacher told me that formula is good for any questions which have exposed area.
Volume(t)=(1/2)*As(t)*h(t) since the volume is 1/2 of a rectangular solid. So you have to use the product rule to get dV/dt. Your teacher may have exaggerated the usefulness of "dh/dt = 1/As x dV/dt". That's only good if As is a constant.
Um, I am sorry I cannot understand. Perhaps if you could explain without As because it's confusing to me.
Please. Thanks.
Good idea. Write a formula for the volume of the pool without using As. V=(1/2)*h*(8m)*(h*24/3). h*24/3 is the length of the filled part. I got that from you 1/3=x/24 by replacing 1 with h. Now how is dV/dt related to dh/dt? Notice As=(8m)*(h*24/3).
sorry for the late reply.
I am extremely confused.
How did you get the formula for the volume of pool? Also, I understand that as the height increases, the volume increases too.
Exposed surface will be a rectangle, so area would be length by width.
I understand the width is 8 m and the length is (24h)/3.
But if we solve the volume formula you gave, we end up with the same conclusion that dh/dt is 1/32 m/min.
Please do explain. I really need to know how this works. Thanks.
I got the formula by multiplying the area of the triangular cross section of the pool by the width. Yes, you get the same answer of 1/32 m/min. Because that's the correct answer. There is also nothing wrong with dV/dt=(1/As)*dh/dt. You seemed to be so convinced you were wrong that you convinced me. Why do you think 1/32 m/min is wrong?
LOL.The reason why I think it's wrong is because my teacher did not give me marks for the answer 1/32 m/min. That is why I think there must be some twist to it.
And when I showed my calculations for h/3 = x/24 the teacher also put a "x" mark there.
Maybe then I did it right, I am not sure.
Well, I think you did it right.
Here is a solution that I present only because you say the (1/32) solution didn’t go well with your instructor. My math, being what it is, I would treat it with suspicion.
Let b be the length of the surface of the water in the 24 meter direction.
Let h be the depth of the water at the deep end of the pool.
Let v be the volume of water in the pool at time t.
b = 12 h
v = (1/2) h (12 h) 8 = 48 h^2
dv/dt = 96 h dh/dt
dh/dt = 1/(96 h) dv/dt
At h = 1 and dv/dt = 2
dh/dt = 1/(96×1)×2 = 1/48
b = 12 h
dv/dt = 96 h dh/dt
That would be fine, except I question the b=12h. At h=0, b=0. At h=3, b=24. So b=8h.
The bottom of the pool terminates at the shallow end at h=2, not h=3. At h=2, b=24.
Oooooooops. You've got it. I was looking at the attached JPG and reading the little tick mark near the 3m label as the depth of the slanted section. Silly me. Sorry. Thanks!
Thanks jimvoit. I finally get it. Your answer was very detailed and it helped me understand this question. The answer 1/48 seems better than the one I got, also the fact that it is 2m and not 3m for the ratios was a small mistake that I had made, but your post was really helpful.
You are the best.
Thanks again.
I’m glad we were able to help out. If there is a lesson here, it is that things can go wrong in at least 2 ways…First if the translation from the description of the physical situation to the math is faulted, and second if the math is faulted. The first way is a real headache because perfectly good math can lead to the wrong answer.
You can also go wrong by focusing on the big picture and forgetting to check the little details. As we did. Thanks again.
  • · Replies 26 ·
13K
