Why Are Electrons Considered Point Particles in Magnetic Moment Studies?
Electrons are considered point particles in magnetic moment studies due to the lack of experimental evidence indicating their structure or finite size. High-energy scattering experiments, such as those conducted at the Large Electron-Positron Collider (LEP), have established upper limits on the electron's size, specifically around 10-19 meters. This upper limit suggests that if electrons possess a size, it must be smaller than this threshold, as no evidence has been found to confirm otherwise. The concept of the magnetic moment of a point charge remains a topic of discussion, but current data supports the point particle model.
  • Understanding of quantum mechanics principles
  • Familiarity with particle physics terminology
  • Knowledge of high-energy scattering experiments
  • Basic comprehension of magnetic moment concepts
  • Research the implications of the electron size limit from LEP experiments
  • Explore the concept of magnetic moment in quantum field theory
  • Investigate alternative models of electron structure
  • Learn about advancements in high-energy physics experiments
Physicists, students of particle physics, and researchers interested in the fundamental properties of electrons and their implications in quantum mechanics.
sudabe
why we take electrons as point particles? just because of its magnetic moment?
maybe there is something wrong with the idea of the magnetic moment of a point charge.
i appreciate if you help.
So far, we have no experimental evidence (from high-energy scattering experiments, for example) that electrons have structure or a finite size. All we can do so far is find upper limits on the size of an electron.
For example, see http://arxiv.org/abs/hep-ph/0002172 which uses an experiment at LEP to set an upper limit of about [itex]10^{-19}[/itex] m for the electron radius. (That doesn't mean that they actually found such a size, it just means that if the electron has a size, it must be smaller than that or else they would have "seen" it.)
  • · Replies 22 ·
  • · Replies 27 ·
